1978 - 1996 Big Bronco
Question about noise after timing chain replacement
Old Nov 13, 2002 | 06:53 PM
fcarruth's Avatar
fcarruth
Thanks for all of you help over the past few days with me replacing my timing chain, water pump, smog pump, thermostat and other minor sensors etc... I figured that since I had it apart, I would do everything that needed to be done.
I just now cranked my Bronco (1989 w/302) and there is a slight piter pater. Does that make sense ? It's hard to describe but it is not something that sounds really that bad.
Here is what I think it could be but want some expertise on it since I am by no means a mechanic. Before I replaced my timing chain and sprockets, I was about 15% out of time. Now that I have a new timing chain, could it be that I just need to set the timing as you normally would with a tuneup etc...? I don't have a timing light so I may take it to a mechanic friend of mine. If it is timing, could I do it if I bought a timing light ? If so, what kind of light do I need ?
Once again, I REALLY, REALLY do appreciate all of the help and responses that I have had from numerous people here at FTE.
Sorry to be so longwinded but I am so grateful for everything.
And yes, I did get the gears perfectly aligned, so that is not an option.
Frank Carruth
1989 EB Bronco w/302
230,000 miles
Old Nov 13, 2002 | 07:03 PM
Mil1ion's Avatar
Mil1ion
If the gear set was put on correctly,the timing light
should be go to go.
Some auto places have a Lend-a-Tool program.
Autozone is one of them.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 13, 2002 | 07:05 PM
fcarruth's Avatar
fcarruth
Thanks Dennis,
I have actually wanted a timing light for 20 years and may just go get one finally.
Thanks for a quict response.
Frank
Old Nov 14, 2002 | 07:12 AM
fcarruth's Avatar
fcarruth
Actually the noise stopped when I started it a second time. Go figure huh ? Anyway, I am going to get my timing set correctly.
Thanks,
Frank
Old Nov 14, 2002 | 07:13 AM
fcarruth's Avatar
fcarruth
projectdagger
Dec 4, 2013 11:50 PM
mikeeeep
1997 - 2003 F150
May 22, 2009 02:04 PM
cfrives3
22
Jul 12, 2007 12:36 AM
BROKEN88F150
Aug 17, 2005 10:01 AM
fcarruth
Nov 11, 2002 12:42 PM
