Ive never done one before, and i don't think i even have the right equipment to do one. However, is it possible to do on on an "old smokey"? If so, whats the procedure if i want it to cook slowly? My only other options are a gas grill, or charcoal grill.
Brisket is a tough (and used to be cheap) cut of meat. The best way to cook it is low heat and sloooooooooooowwww!!! You can even do it in the oven if it will go low enough. Crock pots also work well, one recipe I saw said crock it for 10 hours.
When you're serving, cut it ACROSS the grain. Otherwise it'll be stringy.
He can do it on the Old Smokey. Keep the fire low and the smoke up for a little over an hour and then transfer the meat to one of those foil cooking bags or wrap it in heavy foil and let it keep cooking. Keep the temp around 250* and keep the fat side up. Time on the pit depends on how heavy and thick the cut of meat is. I do briskets all the time both on the pit and in the oven and they always come out great. It's a law in Texas to know how to cook a brisket.
I can't believe that someone in Texas would publicly ask such a question...
I KNOW, i know, but i don't have a pit right now.
Any by God i will if i have to dig a hole in the ground and stand over it with a propane torch until its done.
Im not sure how im going to keep the temp right in an old smokey aside from loading it up with wood and monitoring the air flow. I don't know if that will work. Usually its done by adding wood over a long period.
i do mine with hickory takes about 6hours for a 15lb brisket.low heat around 200 for around 2hours then wrap in tinfoil and put it back on for around another 4 hours .ill turn up the heat to around 350 then ill take it off.like my ol neighbor said you realy have to learn your pit to make great food what works on mine might not work for you
