Aftermarket Products
Sponsored by: Worksport
Spray in liners?
Old Mar 14, 2007 | 01:31 PM
  #46
TruckDaddy's Avatar
TruckDaddy
It's sooooooo easy. Go to www.goline-x.com and use the dealer search function to find the next closest LINE-X dealer.
Firemens Association logo on a door of a Jeep:
Army Paratrooper logo:
Here's one I know you DON'T want:
Old Mar 14, 2007 | 01:55 PM
  #47
Strut61's Avatar
Strut61
The next closest is 2 1/2 hrs away..................
Call Line-X of Pine Grove Pa and tell'um how.
Old Mar 14, 2007 | 04:38 PM
  #48
malcomdavid's Avatar
malcomdavid
the Rhino Linings store in Trenton NJ does some graphics also and check out this website also, www.bedlinergraphics.com for other ideas
Old Mar 14, 2007 | 04:57 PM
  #49
TruckDaddy's Avatar
TruckDaddy
Yep, we use stencils, but not from that particular company. i've never seen a Rhino graphic. Reason: Their liner takes too long to set up so the product would just run. LINE-X dies in 4 seconds. We can make one-time-use stencils ourselves, but here's what the reusable stencils look like:
Old Mar 14, 2007 | 07:49 PM
  #50
Strut61's Avatar
Strut61
Are these "Graphics" something that can be done later......like when the shop I plan to go to figures it out??
Old Mar 14, 2007 | 07:58 PM
  #51
malcomdavid
no, they should be done when the sprayin is happening
Old Mar 14, 2007 | 09:32 PM
  #52
TruckDaddy's Avatar
TruckDaddy
It can be done after the bedliner is applied. But, that means the dealer has to remask your entire truck, blah, blah, blah. So, the best time to do it is when the bedliner is originally installed.
Old Mar 15, 2007 | 04:34 AM
  #53
Strut61's Avatar
Strut61
Ah well, Thanks guy's. This is all a mute point on my end since it won't be happening. Very nice work though and appreciate all the pictures-links and information.
Old Mar 16, 2007 | 01:45 PM
  #54
Strut61's Avatar
Strut61
Well, drove to the shop today and had my new F450 Line-X'd!
Line-X of Pine Grove Pennsylvania, Gary's Autobody are SUPER people!!!!
Even though they did not attempt the graphics they did a 1st rate job......It looks SMOKIN in my truck!!!
Everyone, Thanks for your help and sharing your experience with this product. Made my choice easier! Thanks again
TruckDaddy.......You set a high standard! You ought to be proud, Thank you Sir for your assistance.
Old Apr 7, 2007 | 07:02 PM
  #55
RadarRick's Avatar
RadarRick
Spray in liners
What colors does Line X come in? It appears one color, black.
Does anyone offer colors?
I am not looking for hundreds of colors, but a dark color, a light color. I own a white truck.
Old Apr 7, 2007 | 07:50 PM
  #56
TruckDaddy's Avatar
TruckDaddy
Not all LINE-X dealers offer colors, but the ones that do, colors are literally unlimited. Choose an exact color match or pick whatever you want.
Old Apr 8, 2007 | 09:09 AM
  #57
malcomdavid
Rhino Linings also offer almost unlimited color choices including Solar Max which is a colormatch liner that is as fade resistant as the truck's original paint.
Old Apr 8, 2007 | 09:27 PM
  #58
BigBlueMacDaddy's Avatar
BigBlueMacDaddy
In answer to RadarRick, my local dealers charge $480.00 for a Line-X liner in black. Any other color is $200.00 additional, and is painted on top of the Line-x. The explanation that I was given, is that the line-x colors will change with exposure to the sun, therefore they paint them so they don't change. Like you, I wanted a different color, the light beige to match my interior in my black truck. I thought it would make a nice contrast, but not if I am ever going to have the liner repaired. The installer said that it was extremely hard to match colors if the liner ever needed to be repaired . Looks like it will have to be black for me. Interestingly enough, when I went to look at the shop's work, there was a King Ranch in getting a liner, with the bed matching the upholstery. It did look nice, but I only want to do it once.
Old Apr 9, 2007 | 05:47 AM
  #59
malcomdavid
Check out Rhino Linings Solar Max product. The color is all the way through the liner, not just on top. Also, it isnt suppose to fade like the other peoples liners do in the sun. It is available in almost any color.
Old Apr 9, 2007 | 08:48 AM
  #60
TruckDaddy's Avatar
TruckDaddy
That's not exactly the way it goes with LINE-X. LINE-X uses pigmented resin that's close to the color of your truck. Then, Xtra is applied to get to the exact color. Xtra resists fading, migrates into the bedliner, is scratch resistant, is stain resistant, and maintains its gloss.
SolarMax is an aliphatic product that uses color injection. Aliphatic products are good, but there are some inherent problems with color injection systems both in formulation and getting to the exact color.
