shaky engine pulley
Old Feb 11, 2007 | 07:21 PM
dieseling's Avatar
dieseling
shaky engine pulley
I've got a 2006 F150 5.4L and today after changing the oil I noticed that the ribbed pully between the crankshaft and the powersteering pump pulley wobbles. I can shake it with my hands even with the belt on it. It appears to be an idler pulley...should I be concerned that it wobbles?
Old Feb 11, 2007 | 07:32 PM
screwy's Avatar
screwy
I would be, is the bolt holding it tight?
Welcome to FTE.
Old Feb 11, 2007 | 09:40 PM
dieseling's Avatar
dieseling
Yes, the bolt is tight. I only have 9,000 miles on the truck, surely the sealed bearings aren't bad already? It is strange that it is the only pulley that has slack.
Old Feb 12, 2007 | 10:16 AM
screwy's Avatar
screwy
I'll have a look on my truck, could be you just got a bad pulley.
Old Feb 12, 2007 | 10:20 AM
screwy's Avatar
screwy
I'll have a look on my truck later, could be you just got a bad pulley.
Old Feb 13, 2007 | 09:57 PM
dieseling's Avatar
dieseling
That's true! I'll see what the dealer says about it. Thanks for the input!
Old Feb 15, 2007 | 05:36 PM
Firemut30's Avatar
Firemut30
I have a noise coming from under my hood that sounds like it could be a bearing humming. I'll check mine and see if it is wobbling too!
cowmilker08
Feb 17, 2011 01:29 AM
ericfgs
Sep 30, 2009 03:49 PM
stoney720
Jun 10, 2009 03:33 AM
fatboy*61
Aug 14, 2007 11:15 PM
78sharpshooter
Jun 21, 2007 12:29 AM
