AC Pulley Play (wobble)
Old Sep 27, 2009 | 09:19 AM
ericfgs's Avatar
ericfgs
I have been hearing on occasion (not constant) an awfull noise under the hood. Even when I turn on the ac it doesn't change the depth of sound. I took the belt off and spun the idler pulley, tensioner, and ac pulley. When I spun the ac pulley I notice quite a bit of play (wobble). last summer sometimes I needed to give the clutch a bit of perswasion in order for it to kick in. Is this play (wobble) in the pulley normal? I've never had to replace an ac clutch so I don't have any experience to go on. Thanks!
Old Sep 27, 2009 | 09:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
And the year, series and engine size is?
Wobble is not normal, the pulley's bearing is shot.
Depending on what you are working on, the bearing may be replaceable by itself, otherwise...you'll have to buy the clutch assembly.
Old Sep 27, 2009 | 09:38 AM
ericfgs's Avatar
ericfgs
97 f150 4.6l supercab 130k. Thanks numberdummy. It's kind or where I was leaning but wanted some assurance.
Old Sep 27, 2009 | 09:52 AM
NumberDummy
Y2K FORD PARTS (.COM) has an online parts catalog that is EZ to use.
The link to this site is on this page among the sponsors.
It's faaar easier to use than my Ford parts catalog on microfiche slides is.
According to this catalog, the pulley itself is replaceable as is the clutch. There is no separate bearing listed.
Old Sep 27, 2009 | 10:10 AM
ericfgs's Avatar
ericfgs
I wonder why the bearing isn't listed? If it were included I guess it would be part of the pulley.
Old Sep 27, 2009 | 10:21 AM
ericfgs's Avatar
ericfgs
OK, heres my thought. I've read that shims in the clutch can be tinkered with. That would fix the problem of it not engageing. I did find a bearing locally. I just may go this route rather than replacing the entire clutch assembly. Any thoughts or suggestions?
Old Sep 28, 2009 | 06:45 AM
projectSHO89's Avatar
projectSHO89
This is not an issue with the shims.
I've had this exact failure on my 97. I waited too long, the pulley bearing seized, and my truck rode home on the back of the AAA flatbed because the seized pulley locked the engine up tight. Prior to the catastrophic failure, the clutch plate had been rattling when disengaged. I had purchased a replacement plate from AutoZone but found it wasn't a correct fit. Got sidetracked and didn't follow up right away in getting the correct part. Couple of weeks later, the whole thing went south...
I ordered the Motorcraft pulley and clutch plate from forum sponsor Rockauto. You will need Motorcraft part numbers YS250 & YBR111RM. Less than $100 if you order them.
Old Sep 28, 2009 | 08:01 AM
ericfgs's Avatar
ericfgs
Thanks, the shims were part of a pre-existing problem with the clutch not engaging. Thanks for the info.
Old Sep 30, 2009 | 03:49 PM
ericfgs's Avatar
ericfgs
Found Motorcraft pulley w/bearing!! I couldn't wait to have it shipped to me. I checked Craigs list an I found the pulley at Ford dealership about 1/2 hour from here. The bearing is already pressed in the pulley. It cost me $45 and about 45 min to replace. Plus, I changed the shim so the thing is all better now. Man this forum has saved me a ton of money. I don't know if it's been done yet but I did take pics I could post. Heres the part.
1997 FORD F-150 SUPER CAB 4.6L 281cid V8 FI (W) : Heat & Air Conditioning : A/C Compressor Clutch Pulley Price Core Total
MOTORCRAFT Part # YB522 {Bearing Included #F6TZ19D784A}
Dorsai
17
Jun 14, 2015 07:05 PM
F350_Todd
Mar 25, 2011 04:16 PM
410 Highboy
Feb 12, 2010 02:01 PM
gitane59
Jul 31, 2008 06:53 PM
handyhand
1983 - 2012 Ranger & B-Series
May 7, 2004 06:08 PM
