Waste gate valve
Old Feb 11, 2007 | 10:09 AM
Attilak1's Avatar
Attilak1
Waste gate valve
Can someone show me a picture of a waste gate valve?
Thanks
Attila
Old Feb 11, 2007 | 10:18 AM
BowTieHatr's Avatar
BowTieHatr
6.0s do not have a waste gate
Old Feb 11, 2007 | 10:26 AM
kw5413's Avatar
kw5413
Please verify your '03 engine? 7.3 / 6.0 ?
Old Feb 11, 2007 | 03:12 PM
Attilak1's Avatar
Attilak1
I have a 03, 6.0. When i'm driving i get a air sucking sound when i let my foot off the fuel. I was told this might be the waste gate valve. Does any one know.
Thanks
Attila
Old Feb 11, 2007 | 03:39 PM
phish555's Avatar
phish555
See post #2 above.
Old Feb 11, 2007 | 04:02 PM
Attilak1's Avatar
Attilak1
Anyone have any idea what could be causing my problem? It only happens when I'm letting my foot off the fuel.
Thanks
Old Feb 11, 2007 | 04:57 PM
mhoefer's Avatar
mhoefer
Its a turbo fart, you have no wastegate, so when you let off the throttle, the pressure goes back out through your air cleaner. Not a problem, its not hurting anything.
Old Feb 11, 2007 | 06:21 PM
Attilak1's Avatar
Attilak1
I understand the turbo fart, but now it is doing it as i'm traveling down the road. Even when i'm crusing along at normal speeds. It is constant. It feels like the fuel is cuting out and the truck is bucking, but at the same time it is making that air sucking sound.
Thanks
Attila
Old Feb 11, 2007 | 08:04 PM
npccpartsman's Avatar
npccpartsman
Sounds maybe like you have an exhaust leak or maybe a boost hose with a hole in it. It's possible you've blown a hole in your intercooler. At any rate, that would explain the bucking or fuel cutting out feeling. The computer it trying to compensate for the weird boost or lack of boost by adjusting the VGT. Start at one end of the system and follow it to the other. The exhaust tubes will be really hard to see, but look for excessive black along the firewall or around the back of the turbo. Telltale signs of an exhaust leak.
Old Feb 12, 2007 | 10:14 AM
Attilak1's Avatar
Attilak1
I'll check that out. Thanks
Is there anything else it could be if that not the problem?
Thanks
Attila
Old Feb 12, 2007 | 10:19 AM
Attilak1's Avatar
Attilak1
Thanks I'll check that out.
Is there anything else i should look for that might be causing this problem?
Thanks
Attila
Old Feb 14, 2007 | 08:02 AM
Attilak1's Avatar
Attilak1
What is a VGT?
Thanks
Attila
Old Feb 14, 2007 | 09:11 AM
npccpartsman
http://www.backglass.org/duncan/ps60_manual/
check out this link to the 6.0 bible. Add it to your favorites in your browser. It will give you lots of good info about your engine and even though it has no real tech info maybe it will explain some things that are happening to your motor and where to look.
Old Feb 15, 2007 | 06:19 AM
CanadaGuy's Avatar
CanadaGuy
Originally Posted by Attilak1
What is a VGT?
Thanks
Attila
Variable Geometry Turbocharger.
Jake_f16
Nov 9, 2012 04:45 PM
Yougotthehit
Apr 11, 2012 03:14 PM
Rich in CO
Jun 9, 2006 07:34 PM
rockerf250
Aug 25, 2005 07:36 AM
