"clunk" upon deceleration
Old Feb 11, 2007 | 01:37 AM
boomhowre's Avatar
boomhowre
I recently bought an 88 F150, 302 with an automatic transmission. I've noticed upon deceleration sometimes, like when i take my foot off the gas, there is a clunk or slight "jump" that feel like it's coming from the transmission. Supposedly the tranny was rebuilt fairly recently along with the motor...
Any ideas what it might be or where to look? Also, how bad a problem is this? I mainly use this truck for yard work and hauling my dirtbike around.
Old Feb 11, 2007 | 01:44 AM
jyccustoms's Avatar
jyccustoms
i would put it in park,crawl under the trk and see how loose the ring and pinion are.maybe a u joint?
Old Feb 11, 2007 | 01:46 AM
hillbilly delux's Avatar
hillbilly delux
Check the easy stuff first= see if there is any slop in the u-joints.
Old Feb 11, 2007 | 02:04 AM
jyccustoms's Avatar
jyccustoms
or the ring and pinion,it sounds like the tronny is slowing faster than the rear end,that would make a nice loud clunk,my 88 f150 300-6 mt5od made me kringe when i let off the gas
Old Feb 11, 2007 | 08:05 AM
bohiaa's Avatar
bohiaa
this may not be your issue
but mine was doing this and it was the leaf spring bushings
they were baddd
Old Feb 11, 2007 | 08:15 AM
wizzard351's Avatar
wizzard351
how can you check the u-joints in park? there will be tension on the drive shaft then. i always blocked the wheels and left in neutral to check u-joints.
Old Feb 13, 2007 | 10:35 AM
boomhowre's Avatar
boomhowre
thx guys...I'll get out the ole service manual and look into that stuff, kinda had a feeling it might be u-joints.
Old Feb 13, 2007 | 12:55 PM
gustang818's Avatar
gustang818
Make sure the bolts holding the driveshaft onto the pinion flange are tight. That cured my deceleration clunk.
Old Feb 13, 2007 | 01:17 PM
jyccustoms's Avatar
jyccustoms
your right wizzard,i should have said parking brake.sorry about that.thanks for cetching me.
Old Feb 14, 2007 | 06:27 AM
michiganredneck's Avatar
michiganredneck
I suprised no one said to check trans mount that could be the problem, make sure its not loose or broken. hope this helps you out
Old Feb 14, 2007 | 06:58 AM
subford's Avatar
subford
Sounds like either the anti-clunk spring was left out on the rebuild or the TV adjustment at the throttle valve is out of adjustment.
More than likely the TV adjustment if every thing else is tight.
Forty9ford
May 27, 2016 04:32 PM
Forty9ford
May 27, 2016 01:52 PM
F350-6
May 15, 2016 08:37 PM
run2xs
Mar 7, 2016 10:54 AM
clevo351
Dec 2, 2005 12:28 PM
