Steering rack clunk
Old Nov 29, 2005 | 11:59 PM
clevo351's Avatar
clevo351
Steering rack clunk
My 2000 Explorer has developed a slight clunk in the steering rack. Has anybody else experienced this? Upon investigation, I also found a split in the rubber boot that covers the universal joint, just up from where the steering input shaft goes into the rack. With my finger on the rack and my wife turning the steering wheel from side to side, I can feel the clunk in the rack. When driving it is hard to here the clunk.
Old Dec 1, 2005 | 01:15 PM
gdm1952's Avatar
gdm1952
I think I have the same "clunk" or popping sound in my 98 explorer. It pops with just a slight amount of suspension movement. No squeeks just a pop when it move very slightly. According to some folks on this board, you can clip the boot clamp next to the rack and lube the "dry" joint. Too bad its not at the replaceable tie rod end.
Let me know
GDM
Old Dec 1, 2005 | 06:20 PM
marragtop's Avatar
marragtop
Make sure the 'clunk' isn't caused by loose bolts holding the rack to the suspension.
Old Dec 2, 2005 | 01:43 AM
clevo351's Avatar
clevo351
Rack does not seem to move. Explorer is an Export (RHD). Where does the steering input shaft enter the rack on the left hand drive?
Old Dec 2, 2005 | 12:28 PM
gdm1952's Avatar
gdm1952
Rack is bolted OK. I can definatly pinpoint the popping at the driverside( leftside) tie rod. Much more pronounced the joint next to the rack unit. Used a mechanics stethescope last night
GDM
Kelyn Brown
Jul 19, 2016 11:52 AM
Whisk3y
Jul 14, 2016 06:20 AM
jcweis1
Mar 28, 2015 09:42 PM
we56
Apr 15, 2012 08:58 PM
gt40racing
Nov 15, 2009 08:47 AM
