4x4 not working
Old Apr 3, 2007 | 02:08 PM
  #31
Icy Mike's Avatar
Icy Mike
I had a similiar problem. I replace the transmission position sensor (on the driver's side of the tranny) and the problems went away. I took a whole 15 minutes to fix. It's a dealer part only. I took the old/bad sensor apart and found that it was full of corrosion that prevented good electrical contacts. It cost me $60 at the dealer. I cleaned up the old part and now keep it as a spare. Before you replace the part you may want to take off the old one, drill out the rivets, clean up the corrosion, and replace. You may not need a new part if you can get the old one apart without breaking it. All it really is, is a glorified switch.
Icy Mike
Old Apr 3, 2007 | 10:20 PM
  #32
shellback86's Avatar
shellback86
Trailering
Hi all. I had the 4X4 problem on my 98 a few years back. Do and advance search on my user name shellback86. In a nutshell -
I had to take it to Ford. Here's what you need to do. Disconnect your battery for a couple of minutes to reset your computer. After you reconnect it, try shifting to 4Hi and 4Lo.
If it shifts, it's not your dash switch, vaccum lines, GEM, or fuse/relays. It will be your shift motor on the transfer case which is $300-$400 from Ford(labor not included). Probably much cheaper from a third party parts house. This is a part you can install yourself if you were inclined.
Old Apr 9, 2007 | 08:10 PM
  #33
t0fu's Avatar
t0fu
Tried your advice and it did shift into 4hi and 4lo. Was in a bind because the computer was not giving any service codes but this did work.
Thanks
Old Feb 23, 2008 | 04:15 PM
  #34
Emsand1's Avatar
Emsand1
4WD Not Engaging....disconnect battery.
I know this is an old post but after searching and trying numerous things....
If your 4WD used to work and all of a sudden you get nothing...no dash lights, no 4WD engaging, etc. Try disconnecting the battery and give it another shot. This resets your electronics
glw165
Modular V8 (4.6L, 5.4L)
Dec 14, 2014 05:03 PM
JP_McCann
1997 - 2003 F150
Oct 27, 2009 08:38 PM
bbergman
Feb 3, 2008 04:55 PM
trgrhappy
Nov 12, 2005 08:52 AM
nullp
1978 - 1996 Big Bronco
Jun 24, 2000 12:48 PM
