high pressure release sound
Old Nov 9, 2005 | 11:02 AM
trgrhappy's Avatar
trgrhappy
My 89 f150 started making this weird sound on the way home from work this morning. I haven't been able to pin it down but it seems to come from the front or top of the engine. it sounds like a pressure cooker release and lasts for a second or so. Only does it on acceleration or steady throttle while maintaining speed. Doesn't happen at idle. It doesn't seem to lose power.
It's an 89 F150, 5.0 EFI, automatic, 4X4.
Any ideas?
Old Nov 11, 2005 | 07:46 AM
trgrhappy's Avatar
trgrhappy
Ideas anyone? I could really use some help here.
Old Nov 11, 2005 | 01:21 PM
l-m tech's Avatar
l-m tech
the noise could be the pressure release valve on the a/c popping off.does the sound only happen with the a/c on.
Old Nov 12, 2005 | 08:14 AM
trgrhappy's Avatar
trgrhappy
Hmmmm....now that you mention it, it only happens with the defogger/heater on. but watching the a/c clutch it never seems to dis-engage. (all moving parts always moving) even when the electrical connection disconnected.
Old Nov 12, 2005 | 08:52 AM
blindlightguy's Avatar
blindlightguy
My truck made the same noise when I blew the gasket on the water outlet after changing the thermostat. If the truck is running any hotter then usual or you see any steam I would definitely look at the cooling system.
Blindlightguy
Kdawg89
Oct 16, 2015 02:32 PM
nfazer
2004 - 2008 F150
Dec 7, 2014 10:19 PM
Hunt89
38
Jul 1, 2011 11:13 AM
Rab'66
Apr 16, 2009 05:34 AM
Downriver Thunder
Mar 26, 2006 11:54 AM
