Sponsored by: Real Truck
cold starting problems
Old Feb 10, 2007 | 11:02 AM
duckb52's Avatar
duckb52
Post cold starting problems
I have an F-250 diesel superduty with 216,000 miles. If I plug it in at night it starts and runs fine. If I don't then it starts fine but after about 1 minute it starts running rough cuts off and won't start. I replaced glow plugs and fuel pump but now the mechanic says it has a skip and needs new injectors. Can anyone help!
Old Feb 10, 2007 | 09:46 PM
jbullfrog's Avatar
jbullfrog
Check the voltage. My 2003 has issues in the morning. The Alternator doesn't start charging until you speed it up above 2000 rpm. It pulls the batteries down around 10volts when it starts, but will drop enough that the computer shuts it down if you don't rev it right away to get the alternator started.
Old Feb 11, 2007 | 04:35 PM
duckb52's Avatar
duckb52
I will give this a try and I appreciate you responding!!!
I don't want to spend money on new injectors if I don't need them right now.
Old Feb 11, 2007 | 05:49 PM
just another truck's Avatar
just another truck
also look at the relay's on the left side on the top of the motor for loose or dirty connections,
Old Feb 12, 2007 | 02:18 PM
duckb52's Avatar
duckb52
I do appreciate this information. This is my first diesel and I'm learning.
Thanks Again!!!
StevieMc
13
May 12, 2011 08:03 PM
markwemple
13
Aug 12, 2010 08:10 PM
Chris S
Feb 13, 2008 08:21 PM
snap_on_tootls
Nov 19, 2005 09:17 PM
BenRosey
26
Jan 12, 2004 03:12 PM
