88 7.3l no start
Old Feb 11, 2008 | 07:59 PM
Chris S's Avatar
Chris S
Smile 88 7.3l no start
Hi, I'am new to the diesel world and just bought a '88 f-250 with the 7.3l I was woundering if anyone can help me? The truck was running great and would start right up, it sat over night and now it will not start, it cranks over fine but it will not fire, I tested the glow plugs and they all tested fine, the batteries are good,the fuel pressure is good, where should i check from here. Thank you
Old Feb 11, 2008 | 08:17 PM
PLC7.3's Avatar
PLC7.3
Check that all the electrical connections on the IP have power on a cold engine......KEY ON.
Old Feb 11, 2008 | 08:22 PM
George D.'s Avatar
George D.
If you have fule presure it sounds like you're not geting power to you're fule solinoid. Also is your gp controller working?
Old Feb 11, 2008 | 10:26 PM
Chris S's Avatar
Chris S
Thank you for your advice, and i don't know what IP stands for?, thanks
Old Feb 11, 2008 | 10:37 PM
7.3 idi bandit's Avatar
7.3 idi bandit
Injection Pump = IP ...i learned that in calculus today haha.. I wish
Old Feb 11, 2008 | 10:51 PM
George D.'s Avatar
George D.
The in jection pump is located in the valley on the back of the front cover. It will ne the thing with all the lines going to the injectors coming off it. There will be 3 wires conected too it. with the engine cold and the key on check for power at each wire. Can't remeber wich is wich. Dave S. should be along shortly and I think he has a picture of the pump and the wires.
Old Feb 12, 2008 | 12:45 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Chris S,
Welcome to FTE and the IDI forum.
This one?
With a cold engine there should be power on all three wires when the key is ON.
With a warm engine, over 117 degrees, there should only be power on the fuel shut off solenoid when the key is ON.
Old Feb 12, 2008 | 06:35 PM
Chris S's Avatar
Chris S
Thank you for your help i'am going to go check every now
Old Feb 12, 2008 | 06:38 PM
George D.'s Avatar
George D.
Yep that one.
Old Feb 13, 2008 | 08:21 PM
Chris S's Avatar
Chris S
thanks for your help, it turned out to be the fuel solenoid
Ken Claydon
Apr 13, 2020 10:42 PM
alaskan_diesel_88
May 31, 2010 09:59 AM
dually88
May 20, 2010 11:23 PM
codys50ford
Jun 12, 2008 06:37 AM
mmwalzer
Feb 8, 2007 05:06 PM
