1978 - 1996 Big Bronco
No Power to stereo
Old Dec 8, 2002 | 10:27 PM
Bulldog424's Avatar
Bulldog424
No Power to stereo
I just installed a new stereo in my 1994 bronco and it will not turn on. I checked power wires with a test light. ignition wire works fine but no power to battery wire on either side of the harness. All connections are good and all fuses in box are fine. Is there an in line fuse to this wire?
Old Dec 8, 2002 | 10:30 PM
83bigbroncoguy's Avatar
83bigbroncoguy
No Power to stereo
Triple-check the ground wire. There wasn't an inline fuse on my Bronco until I put one in with the radio. The later models may be different. Pull the radio back out (I know it's not fun...I pulled mine countless times) and check for an inline fuse.
Old Dec 8, 2002 | 11:16 PM
mweeps's Avatar
mweeps
No Power to stereo
What kind of deck? Does it have an internal fuse?
Old Dec 8, 2002 | 11:26 PM
Bulldog424's Avatar
Bulldog424
No Power to stereo
It is a pioneer deck and it does have an internal fuse which is also good.
Old Dec 8, 2002 | 11:53 PM
blownbronco's Avatar
blownbronco
No Power to stereo
I have a rampage stereo it came with a black wire that had to be connect to the frame of my truck. There was also a red wire which is the power wire. If you have these wires check them!! HOPE THIS HELPS!!!!!!:-X12
Old Dec 9, 2002 | 09:02 AM
90EBBronco's Avatar
90EBBronco
No Power to stereo
When connecting a new stereo you deal with 3 wires which are essential. The constant 12V, the switching power wire and the ground. If the ground wire is not attached securely to a clean metal surface the stereo will not work. Check it and if need be position it somewhere else on the truck behind the dash. Make sure your switching 12v and constant 12v wires are in correct orientation. Do you have the adapter from the Ford connector to you new setup or have you hard wired the harness? If your wiring setup is all correct get in there with a multimeter and check the continuity of the wires to make sure that one of them doesn't have a break in it somewhere. Those wires are thin and can break easily if they get pinched or pulled too hard. Hope this helps. Good luck!
KJ
Old Dec 9, 2002 | 11:50 AM
boobarrie's Avatar
boobarrie
No Power to stereo
Riddick6464
Mar 31, 2016 09:23 AM
robengel
Aug 19, 2015 03:54 PM
jomoflymo
Aug 16, 2015 07:12 PM
emenko0809
Jul 7, 2015 06:43 AM
dakotarider
2009 - 2014 F150
May 2, 2015 06:22 AM
