351W vs 302 flexplate.
Old Feb 8, 2007 | 01:57 PM
scottie2hottie's Avatar
scottie2hottie
Ok- I have an 87 302 I just rebuilt, and have an 87 351W for parts. Can I use the flexplate from the 351W on the 302? Supposedly they are the same weight, same bellhousing, same starter used, same tranny/torque convertor. Thanks.
Old Feb 8, 2007 | 02:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1981/ 302 .. E1TZ-6375-C w/C-6
1984/ 351W .. D1ZZ-6375-A w/C-6
However, if both the 302 and 351W were from 1980 only D1ZZ-6375-A would work for both.
There are a bunch of different flywheels for the 80's 302/351W trucks (CA, non CA w/ or w/o this or that etc)...after checking everything thrice..this info is correct.
Old Feb 8, 2007 | 02:31 PM
scottie2hottie
C6 in both instances.
Old Feb 8, 2007 | 02:49 PM
NumberDummy
updated ^^^post
Old Feb 8, 2007 | 04:09 PM
scottie2hottie
can you vfy why there is a difference?
Old Feb 8, 2007 | 04:16 PM
NumberDummy
Can I verify?...I was afraid you'd ask me this...more squinting into the dang viewer
Give me 10 minutes....
Old Feb 8, 2007 | 04:17 PM
scottie2hottie
LOL thanks bill.
Old Feb 8, 2007 | 04:31 PM
HemiEater's Avatar
HemiEater
the 302 would be 50oz balance
all 351W are 28oz.....
so no it wont work........
Old Feb 8, 2007 | 04:55 PM
NumberDummy
LOL thanks bill.
HemiEater..where were you 20 minutes ago when I needed you...LOL
It's a matter of balance.
302's
1980 uses D1ZZ-6375-A Flywheel
1980 uses D8TZ-6316-B Vibration Damper
1981/89 uses E1TZ-6375-C Flywheel
1981 uses E1TZ 6316-D Vibration Damper
1982/83 uses E1TZ-6316-A Vibration Damper
1984/89 uses E4TZ-6316-A Vibration Damper
351W
1980/89 (exc 1981 CA) uses D1ZZ-6375-A Flywheel
1981 (CA only) uses E0AZ-6375-A Flywheel
1980 uses D2AZ-6316-A Vibration Damper
1981/84 w/o EEC uses E4TZ-6316-B Vibration Damper
1981/83 with EEC uses E1TZ-6316-B Vibration Damper
1985/87 uses E4TZ-6316-B Vibration Damper
1988/89 uses E8TZ-6316-B Vibration Damper
See if you can find a combo that works, I can't..I can barely see. After trying to decipher all this rigamarole, using a viewer with scratchy slides, I'm unbalanced!
Old Feb 8, 2007 | 05:19 PM
baddad457's Avatar
baddad457
87 302 needs a 50 oz balance flexplate, the 351W's were all 28 oz.
Old Feb 8, 2007 | 06:17 PM
scottie2hottie
Thanks everyone!
andrew's64
Aug 6, 2016 05:50 PM
BuickBrian
Jan 25, 2016 06:59 AM
thuli22
May 10, 2015 02:35 PM
300inline6
Dec 19, 2005 10:16 PM
wozxxx86
Dec 10, 2004 03:26 PM
