Valve Spring Question
Old Feb 8, 2007 | 11:18 PM
Hypoid's Avatar
Hypoid
The world just keeps getting smaller Jake. My ex in-laws (outlaws?) used to be caretakers at Bader Pits. I used to have a key to the gate...20 years ago.
Are the pits still open to the public?
Old Feb 9, 2007 | 04:46 PM
jseim44's Avatar
jseim44
Yea, Bader is still open!!!! I've never been there though. From what I've heard the people that run it now are charging people through the nose to get in and what not (not really how it's s'posed to be run).
To keep this somewhat FE related - I just got back from the machine shop. Block is bored .030 and crank is turned .010/.010. I'm getting very excited about getting this thing back together and hearing it run again. It should make some pretty good power for my ol' 3/4 ton!!!!
-Jake
Old Feb 26, 2007 | 06:36 PM
jseim44's Avatar
jseim44
Just getting this updated and back on track.....Comp recommends the 926 valve springs for the 280H that I'm running. These are only a single spring. Since they're recommending them I'm not in doubt that will handle the lift and duration. The thing I'm wondering about is if I should spend the money on all new locks and retainers. I figure with the retainers - yes, most likely that would be the best move. However, I don't know if I would really need new locks?
Sorry about all the questions. I'm pretty new to this and am finding out that I know more about a 390 Ford than my auto teacher (although that doesn't take much). I just don't want to screw this up!!!
Thanks
-Jake
Old Feb 26, 2007 | 08:14 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well Retainers and locks are cheap enough...Anytime you replace old used..your a step ahead of the game for insurance!! JMO
RJ
Old Feb 26, 2007 | 08:17 PM
aMoneypit's Avatar
aMoneypit
Yes buy the locks, probably the cheapest insurance you'll ever find.
On the spring subject, there was a thread at a different site that had super slo mo of springs in action at various RPMs and the harmonics involved. Talk about scary!! Those springs were doing all sorts of dancing around, rebounding off the seat, different coils going in different directions, and the valve stems actually flexing sideways.........WOW scary, and the film was done on a Nextel cup engine!!! aMP
Old Feb 27, 2007 | 12:33 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
I replaced Ford's keepers years ago with Manley's chromoly keepers, get them in standard, +.050" and -.050".
Old Feb 27, 2007 | 04:39 PM
jseim44's Avatar
jseim44
That's kind of what I expected to hear from you guys. Thanks again for all the advice. I will order the Comp springs, retainers, and locks in short order!!!!
-Jake
Old Feb 27, 2007 | 08:14 PM
"Beemer Nut"
Check the cam and spring manufacture for the required seat pressure and assembled height. Between the use of different height keepers and shims you can get within .010" of the assembled height for the correct seat pressure.
Some machine shops will do a "that's good enough" type of work where you'll have too high of seat pressure on some valves with others in spec.
1978fordxltranger
Jul 10, 2014 09:30 PM
MONAVIERONJON
Aug 30, 2012 01:23 AM
strokerfe
Apr 9, 2011 10:15 PM
mdr617
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 11, 2011 01:55 PM
95F150Guy
Jan 2, 2011 11:47 AM
