Abomination!
Old Feb 7, 2007 | 08:20 PM
stoneattic's Avatar
stoneattic
Just to set the record straight, I didn't do the swap. I actually got the truck as part of a trade. I use it to haul lumber, drywall, etc, when doing home improvement projects.
Yes, it has plenty of power. Yes, the engine and trans are wet with fluids, but it's not wet enough to drip. I didn't put the chrome on. Yes, the d-shaft should be an inch or two longer but it's been like that for 8 years without any problems.
Old Feb 7, 2007 | 08:27 PM
Tractor Boy's Avatar
Tractor Boy
i have a small block ford and 4 speed toploader that run/shift great and have no leaks, i'll offer them free as long as u dump the mopar junk out..............lmao
Old Feb 7, 2007 | 08:39 PM
scottie2hottie's Avatar
scottie2hottie
I'll dump A LOT of stuff for a free toploader- those don't go cheap round these parts.
Old Feb 7, 2007 | 09:43 PM
stoneattic's Avatar
stoneattic
Are they for me to toss in the bed to help out with traction?
Old Feb 7, 2007 | 11:16 PM
monckywrench's Avatar
monckywrench
I like it. Good parts, and annoys brand purists on both sides.
Old Feb 8, 2007 | 07:53 AM
scottie2hottie
Very true there- I'll have to get some pics of my buddie's mud rig. He's got an old S10 blazer(the small ones) on an old 66-77 bronco frame, he swapped in a Dana 44 out of international scout (for the passenger side pig up front) and runs a mopar 360/727/NP203. It's actually done very nicely and you wouldn't know it was such a chop job.
Old Feb 8, 2007 | 07:56 AM
scottie2hottie
Here's a pic of it, although it's muddy. He's got it painted pretty nice to. And he fabbed the toneau cover on the back(he chopped off the passenger compartment) He's a pretty decent fiberglass worker.
http://crumsmudrun.com/septmudrun%20088.jpg
Old Feb 8, 2007 | 09:58 AM
ezryder13's Avatar
ezryder13
aaaaah yes nothing like a bunch of HIENZ 57 junk floatin around..alot more of them then we think!
Old Feb 8, 2007 | 12:58 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
So how does that 440 breathe with that closed off air cleaner?
Old Feb 8, 2007 | 01:21 PM
stoneattic's Avatar
stoneattic
It's not closed off. It's opened all the way around the bottom. The lower piece is the same diameter as a regular open element cleaner.
Old Feb 8, 2007 | 05:58 PM
77460ford's Avatar
77460ford
How about going to another extreme. I've found two F-series trucks that are putting this monster in:
An all aluminum ford V8, the GAA. It's the 1100CID monster that was found in Sherman tanks. Just over 1000ft/lbs of torque off idle.
Old Feb 8, 2007 | 06:21 PM
Tractor Boy
AWESOME!!!!!!! I WANT THAT!!!!! where can I get one???
Old Feb 8, 2007 | 06:29 PM
  #28
77460ford's Avatar
77460ford
This is one of those hidden gems that turns up in the oddest places. It's about 900lbs without front accessories (when put on a diet) and parts are hard to find. The neat part is the 60 degree's between cylinders which makes it narrow and it's only 4" longer than the I6 engine. 4 valve cyclinder heads with twin gear driven cams. Ford I believe had it as a 12 cylinder for aircraft use and loped off 4 cylinders for the Shermans.
Old Feb 8, 2007 | 06:47 PM
  #29
FordBoypete's Avatar
FordBoypete
The truck this topic is originally about certainly is well named.
I've crushed trucks nicer than it. How did it ever get tags on it with problems visible in pictures, especially in the Keystone State ? . . . . or are they "NQL" tags?
Is it true MOPAR is an acronym for Motor On Pavement After Race? Why did you post this on a Ford Truck Enthusiast site, do you want sympathy? Hope not we laugh at stuff like this truck represents where I am.
Good Luck Anyway.
FBp
Old Feb 8, 2007 | 07:18 PM
  #30
79-400-POWER's Avatar
79-400-POWER
Looks like somebody missed snak time.
