Symptoms of a wiped cam?
I'm looking around trying to find the symptoms of a cam with flat lobes. I think i goofed when i re-assembled my engine and it took the cam out. Would i be looking for a rough, lope like idle? Or just backfiring/missing and a constant rich fuel smell? My truck has a few of these symptoms... and i'm just curious.
Thanks Ya'll
Thanks Ya'll
Well the whole reason for this thread was the fact that my 300 has a rattle that will not go away. The engine is quiet while cold, and will not rattle while not under a load. Only after the engine is warm and i'm driving it down the road will it rattle. Though it usually doesn't do it at just any rpm/speed it mostly does it above 55mph. The noise is so loud i can hardly hear myself think. I know it isn't rod knock...and i've played with the valvetrain once or twice and gotten it quiet..but the sound keeps returning.
For all i know the cam may be fine.. and the rocker arm studs could be pulling out and causing all the problems...
Timing is set at factory 10*. I'm certain it isn't pinging... its definately in the rockers. Like i said i can adjust the rockers and it'll go away. So i'm certain it isn't that.
I just wish there was a deciding factor that would say definatively it was the cam, or the studs in the head had been pulled up by me over tightening them or something.
There is a way to check cam lobe wear by removing the valve cover, collapsing the hydraulic lifter by putting pressure on the valve push rod, and measuring with a dial indicator. I've done it, but it has been so long ago that I can't remember the details. It's worth doing before giving up on your cam. It is how I found out that mine was bad after chasing a mysterious miss for over two years. Good luck.
greasolution
18
02-29-2016 08:53 PM
