4V 5.4 startup clatter (2004 Navigator)
Old 01-17-2017, 08:59 AM
MackGuy's Avatar
MackGuy
MackGuy is offline
Just wanted to see if anyone has any thoughts on this... When starting my 04 navigator, it has a little clatter at first startup, but settles into very smooth idle, and no symptoms while driving. I know sometimes with DOHC engines this is "normal" since it just takes a bit longer for oil to get up to the cam/valvetrain, but wanted to see if that's typical on these engines, or something I should look into. Just under 150k miles.
Old 01-18-2017, 08:13 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,180 Likes on 811 Posts
Clatter is not normal, how old is your oil? What weight are you using? And what brand of oil filter?
99% of the time is due to timing chain guides wearing out or tensioners loosing their prime.
Old 01-18-2017, 08:34 PM
MackGuy's Avatar
MackGuy
MackGuy is offline
We just bought it in November, but service records are complete. Now it has whatever the dealer put in, was changed in December.
It's just a 2 sec thing at startup, maybe I can get a phone video. Tensioners losing prime sounds interesting.
Old 01-23-2017, 12:29 PM
Garden Spyder's Avatar
Garden Spyder
Garden Spyder is offline
I don't know if the 4 valve tensioners is the same as the 3 valve, but mine had a seal blown out on the back side of the tensioner, which would bleed down while the engine sat for longer than 2 minutes, then I would get the chatter you speak of, till the pump filled the void of oil that was missing. For me, it was a second or two max, then all was fine after that.
Tomstowe
2009 - 2014 F150
08-28-2014 09:50 PM
Bubble-City
1999 to 2016 Super Duty
09-27-2012 09:31 PM
speedtrash
1997 - 2003 F150
06-17-2011 05:21 PM
mswpj
2004 - 2008 F150
09-20-2008 09:15 AM
hank farmer
2004 - 2008 F150
10-18-2006 02:01 PM
Quick Reply: 4V 5.4 startup clatter (2004 Navigator)
