My serpentine belt came off yesterday as I was on my way home yesterday. The old belt was still in one piece, it was just off. As I looked it over I determined to get a new one. I put it on my truck this morning but it is rea loose. I started my truck the belt turns, but is very squeaky (Very Loud). What is a remedy for this?
Get the correct lenght belt so your tensioner will work right, or if that is'nt the
problem I have used a wax candle to run under the belt as it is turning, but a
warning be sure to keep your HANDS out of the way of moving parts when you
do this.
I would guess your tensioner is shot, since your belt came off by its self.
Also check all the pulleys to make sure the belt is running in the center. Also make sure the belt is routed correctly.
