Hi all,
I noticed recently taht my belt is getting squeaky. It's worse when it's humid. Should I get a new serp belt? Or put dressing on it or something?
Thanks
You may want to look things over before you replace the belt though. May be a bearing starting to go in a tensioner pulley or any of the other devices hung in the loop, just something to consider.
I usually replace the tensioner when I replace a belt. It usually costs around $50 or less and it's worth the peace of mind IMO. I've had them go bad on both of the minivans I had. I learned my lesson after the first one.
I've never had good luck with spray stuff. It only cures the symptom anyway (briefly if at all). It's not like the old days where if you threw a belt (usually the small one) you were only out A/C and power steering until you could get to the auto parts store.
