IAT sensor???
Old Feb 6, 2007 | 08:43 AM
JBrown24's Avatar
JBrown24
IAT sensor???
I have an '01 Sport Trac with the 4.0 SOHC engine. According to the repair manual I bought, there is an Intake Air Temp (IAT) sensor that should be located in the intake tube, between the air box and the throttle body, and close to the MAF sensor. I looked, but there is no such sensor on my intake tube. Since I am having a cold start issue, I wanted to verify that this sensor was working, but I can't locate it. Could it be part of the MAF???
Old Feb 6, 2007 | 10:28 AM
87 XLT's Avatar
87 XLT
Dont know if yours is the same, but the 97 EVTM shows it's near the throttle plate with a dark green & a gray/red stripe wire.
Old Feb 6, 2007 | 01:43 PM
JBrown24's Avatar
JBrown24
The only sensors on or near that inlet tube/throttle body that I can find are the throttle position sensor, the MAF, and the idle air control valve. Below the throttle body is the coolant temp sensor and the sending unit for the temp gauge. I've identified these according to the pics in the repair manual, but the IAT sensor is just not where it shows it to be. I just wondered if maybe Ford decided to combine it with the MAF somehow, because the picture shows the two being right next to each other on the intake tube.
Old Feb 6, 2007 | 05:59 PM
87 XLT's Avatar
87 XLT
Yeah, they must have moved it then. Maybe inside the air filter housing?
But if the IAT was bad you should get a check engine light and an IAT trouble code.
Is it slow to start? Could be a weak fuel pump if thats the case.
If thats the problem try cycling the key to run for 2 seconds then off. Repeat 5 times & see how it starts.
Old Feb 6, 2007 | 06:53 PM
JBrown24's Avatar
JBrown24
Yeah, all good suggestions. I'll check the air filter housing. I went to the local parts store and they list an IAT sensor for my year and model. I was able to look at a closer picture of it, so at least now I know what I am looking for. Good point about the code and check engine light. I checked to see if there were any codes stored in the computer while I was at the parts store, but there was nothing. At this point, it's starting to look like a fuel issue. A friend suggested I buy some starting fluid and shoot some into the intake before starting. He said that if it starts, but dies right away, that would suggest a weak fuel pump, since I don't have a pressure gauge to test it properly. I'll try that in the morning and see what happens.
Old Feb 7, 2007 | 09:39 PM
JBrown24's Avatar
JBrown24
I tried cycling the key 5 times before attempting to start this morning, but it still didn't want to start. I sprayed some starting fluid in the intake tube and tried again, and even then it didn't fire right away. It took a couple of cranks (which it kinda acted like it wanted to start) before it actually started. The starting fluid did keep me from having to crank on it forever though. Not sure what this means, really. Any other thoughts?
Old Feb 8, 2007 | 02:04 AM
87 XLT's Avatar
87 XLT
So theres no codes, cycling the key & starter fluid did'nt help.
If it starts easily when it's warmed up, take a look at the top of the Ranger forum & click on "Ranger technical info" & then on "ECT testing"
The ECT/engine coolant temp sensor is the electronic version of a choke. It tells the PCM whether the engine is cold or warmed up.
The sensor will have 2 wires attached & is near the thermostat housing.
Old Feb 8, 2007 | 07:10 AM
JBrown24's Avatar
JBrown24
Yep....already replaced that. Here's the list of stuff I have checked/replaced: MAF sensor(tested ok), ECT sensor(replaced), Intake Manifold gaskets(replaced), IAC Valve(tested ok), replaced the spark plugs, plug wires, and fuel filter. Next on my list of things to do is to check the fuel pressure with a pressure gauge and clean the MAF sensor. I got in it this morning and it fired right up...no starting fluid and no cycling of the key needed. The only thing that was different than my normal routine was the fact that I didn't get home until about 10:30 last night, so it didn't sit for as long. However, this doesn't always make a difference. Here's a question though: If the fuel pump is weak, is it always weak, or could it be intermittently weak? In other words, could there be times when it functions normally, and other times when it doesn't? It seems like my problem is really intermittent, though lately it has been happening more with the cold weather.
Old Feb 8, 2007 | 11:58 AM
87 XLT's Avatar
87 XLT
So theres no codes, a new CTS & it wont fire on the starting fluid. No spark maybe?
Try connecting a timing light to one of the plug wires & see if you are getting a good strong spark.
If the fuel pump was weak, it might be too lean to start, but it should still fire right up on the starting fluid.
Old Feb 8, 2007 | 01:52 PM
JBrown24's Avatar
JBrown24
Thanks...I'll check that as well.
southern hunter56
Mar 23, 2011 04:20 PM
PeterSr
Jan 12, 2011 08:20 PM
tbar
Nov 12, 2004 06:40 AM
76fordman
Jul 28, 2004 07:16 PM
firefighter525
1983 - 2012 Ranger & B-Series
Mar 13, 2003 06:12 AM
