1978 - 1996 Big Bronco
Failed SMOG check....
Old Nov 9, 2002 | 01:52 PM
Pioneer Ford's Avatar
Pioneer Ford
I Just had my truck smog checked and it passes everything with flying colors except for the NO (PPM) (Nitrous Oxide parts per million). Those readings were pretty high. Anyone else fail because of this? What's the solution? I don't feel like paying $100 for someone to tell me it's a $20 part. How would I be able to tell if it's the catalytic converter? Thanks for the help.
Old Nov 9, 2002 | 02:28 PM
Ford_Six's Avatar
Ford_Six
What were your exact numbers for everything, and what is the year/engine of your truck? Is it carbureted?
Jared
Old Nov 9, 2002 | 03:19 PM
Pioneer Ford
I failed with a 1200 on the "N.O.(PPM)" reading. Max pass reading is around 950. It's a EFI 351 auto. Thanks
Old Nov 9, 2002 | 04:49 PM
Ford_Six's Avatar
Ford_Six
what were the Co and HC readings? It's starting to sound like a plugged egr, but I need more numbers.
Jared
Old Nov 10, 2002 | 01:52 PM
Pioneer Ford
[updated:LAST EDITED ON 10-Nov-02 AT 02:53 PM (EST)]Well, turns out that 4 of the 5 vacume lines way behind the upper intake manifold were completly broken and burnt, one of which goes directly to the EGR valve. I took off the manifold, replaced all of the lines, and even replaced the fuel pressure regulator while I was back there. I will re-test soon. Thanks
Old Nov 10, 2002 | 02:44 PM
greystreak92's Avatar
greystreak92
Pioneer,
If those lines wre bunrt or heat-brittle check for a loose or broken air injection check valve back there. There is one in the air injection crossover pipe that runs behind the intake and a hose from the smog pump. I had this check valve crack open and it was letting hot exhaust back up through it and it did the same thing (burnt and crispered) the vaccuum lines back there. Also wreaked havoc my emmissions since one bank of cylinders wasn't getting fresh air from the smog pump.
Old Nov 12, 2002 | 06:07 PM
Pioneer Ford
Thanks for the heads-up. I actually wrapped the lines in aluminum foil to help prevent the melting from happening again, but I will also check the air injection line. Thanks again
Old Nov 14, 2002 | 01:01 PM
Redbob's Avatar
Redbob
Fixing those bad lines will probably take care of the problem, but if you need it, you can a slight further reduction in NOx by retarding the timing a few degrees - just for the smog test, of course.
Old Nov 14, 2002 | 05:14 PM
Pioneer Ford
Thanks for the advice, but now I have another problem. After fixing the lines, the truck runs smoother, but has less power than before. Is this because the EGR is actually working now? I actually removed the upper intake manifold to replace the broken lines and thought that I might have a small vacume leak, but since the engine runs very smooth, I don't think that's it, I don't know. Any ideas? Thanks
Old Dec 16, 2002 | 04:57 PM
kevinrea's Avatar
kevinrea
i had this same problem. i could not get my truck smoged for about 7 months past it's due date.
the problem on mine was that the line leading from the back of my egr valve was completely clogged up with gunk..
the mechanic used a drill motor with a bent piece of wire to roto rooter the thing out..
it passed with flying colors after that.
mine is a 1986 w/203
full size bronco.
Old Dec 18, 2002 | 12:11 PM
Pioneer Ford
Just an update...It passed with flying colors after fixing the vacume lines. Just goes to show that every little thing makes a difference.
Old Dec 18, 2002 | 12:18 PM
CityBronco's Avatar
CityBronco
gixxer1
Mar 13, 2006 11:01 AM
edub32
Bio-diesel, Propane & Alternative Diesel Engine Fuels
15
Apr 9, 2005 05:33 AM
4.9LFord
Feb 2, 2005 07:22 PM
tsdrallyer
Jul 12, 2003 11:46 AM
RCW
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Mar 29, 2002 05:22 PM
