Bronco II Ford Bronco II
Diff. fluid
Old Feb 5, 2007 | 09:14 PM
Canadianice's Avatar
Canadianice
Diff. fluid
I have an 84 Bronco II with a traction lock rear end, I was woundering what fluid I need to change the old stuff out with?
Old Feb 5, 2007 | 09:38 PM
kernel-panic's Avatar
kernel-panic
Hypoid Gear lubricant, Ford Part #E0AZ-19580-A, with 4 oz. of Friction Modifier Ford Part# C8AZ-19B546-A (or their equivalents) for the 7.5 rear axle.
Hypoid Gear lubricant, Ford Part #C6AZ-19580-E, with 1/2 oz. of Friction Modifier Ford Part# C8AZ-19B546-A (or their equivalents) for the Dana 28 front axle.
More info
Old Feb 18, 2007 | 07:45 PM
dirtybroncoii's Avatar
dirtybroncoii
If you want the Trac-Loc to grab a little bit more don't put the friction modifier in. What that stuff does is make the gear oil more slick. and if you don't use it the friction disks in there will grab harder. And it wont harm the frictions or the rear end if you don't use it.
Old Feb 19, 2007 | 07:27 AM
kernel-panic
Actually, the friction modifier keeps the clutches from slipping. Not putting it in will burn up the differential. Buddy of mine burned up 3 different Ford 9" Trac-lok diffs that way.
mattymax
Oct 16, 2016 04:15 PM
good to doo
Jun 29, 2016 09:55 AM
abyars111
Apr 16, 2013 05:36 PM
Nice Work Truck
Oct 25, 2009 11:44 PM
MJW
Mar 26, 2004 10:17 AM
