Body swap
Old Feb 5, 2007 | 07:04 PM
wadar1969's Avatar
wadar1969
Body swap
I am rebuilding a 1978 ford short bed I am wondering what year model bodiy will bolt onto the frame without much modifications
Thanks Wade
Old Feb 5, 2007 | 10:43 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Pretty much any 73-79 F-series pickup. You might even be able to swap a 67-72 F-series pickup body. Take lots of measurements before you buy something you arent sure of.
Old Feb 6, 2007 | 08:54 PM
projectdagger's Avatar
projectdagger
the 76 body is a direct replacement. I have a 76 f-100, about 10 years ago i put a 78 cab and front clip on it. But i afraid that i Can not answer about the bed.
Old Feb 6, 2007 | 09:12 PM
willydad's Avatar
willydad
67-72 trucks have narrower frames
Old Feb 6, 2007 | 09:37 PM
1ole4d's Avatar
1ole4d
To answer your question, any F100-F350 body, bed, hood, and fenders will swap with your 78. Obviously though you can't place a short bed box on a long bed frame and vise versa but you get the idea.
Old Feb 8, 2007 | 03:05 PM
samickguy15's Avatar
samickguy15
You can swap any cab/bed from 73-79, with the exception of the Highboys as they carry a different rear frame width. The cabs will all bolt up the same, but you will have to modify the bed if you swap highboy/non-highboy. Just swapped a 75 body onto my 78 chasis. No problems except for the rusty old bolts and cab mount bushings...
Old Feb 8, 2007 | 06:43 PM
toyotaguy's Avatar
toyotaguy
i took a 73 std cab long bed and replaced the std cab with a super cab. it can be done but with lots of modifications. then replaced the 73 front end with a 96 conversion kit.
Old Feb 8, 2007 | 06:46 PM
projectdagger
a 96 conversion kit??
Old Feb 8, 2007 | 06:57 PM
toyotaguy's Avatar
toyotaguy
ya the fiberglass converts the front end to a 92-96 f 150 front end
Old Feb 8, 2007 | 11:47 PM
projectdagger
i looked at the pictures of your truck. that is pretty sweet. I am curious, who makes the conversion kit?
Old Feb 13, 2007 | 12:31 AM
toyotaguy's Avatar
toyotaguy
a small company in san diego called perrys fab and fiber. they sell the hood and fenders. then you get a core support lights and grill off of a 92-96 f150. it makes a one of a kind truck.
Old Feb 13, 2007 | 06:25 PM
projectdagger
many thanks for the informations
Old Feb 18, 2007 | 05:17 PM
1977f250's Avatar
1977f250
hey toyotaguy you took a standard cab longbed and replaced it with a supercab, how did the short box fit up to it?
Old Feb 18, 2007 | 07:21 PM
big_daddy_bigfoot's Avatar
big_daddy_bigfoot
The beds will bolt on you just cant use all the bolt holes right? I know I have seen guys do that around here.
My 79 f250 ( I know it's not a highboy) has a 78 f150 cab so I know you can switch cabs at least.
Old Feb 20, 2007 | 10:39 PM
toyotaguy's Avatar
toyotaguy
well...... the bed was totaly scrapped, and all i used was the sheet metal bed skins. i cut the front off of the existing bed and sectioned a part out of the bedside. so i turned them into short bed sides. for one lightining the truck and allowing for the roll cage.
powerstrokeddiesel
28
Nov 7, 2007 09:25 PM
carpe_diem
107
Dec 6, 2003 10:25 PM
Mike W
15
Sep 8, 2003 12:00 AM
logan_85
Oct 6, 2002 06:10 PM
martinb
Feb 9, 2001 07:17 PM
