Sponsored by: Auxito
Tranny Problem?
Old Feb 1, 2007 | 08:42 PM
ahall8's Avatar
ahall8
Tranny Problem?
I have found a new problem with my '97 4x4 f150 and I'm hoping for something other than the worst. The mileage is unknow as it was supposed to have 30k on the tranny when I got it but who knows. It has always felt a little hard kicking into OD and down on the highway, but the other day as I stopped at a stop sign and the truck completly stopped and then it thumped. It felt like it was just under me. It was snowing bad so I thought nothing of it. But it has happend for 2 days now. The U-joints appear ok and the tranny fluid level is fine. Any ideas are really appreciated.
Old Feb 1, 2007 | 08:58 PM
ahall8's Avatar
ahall8
Oh almost forgot. I did just change my IAC because it would not idle. So obviously the truck idles higher now. Possibly it is the rear brakes hanging and letting off?
Old Feb 2, 2007 | 12:51 AM
wgotthardt's Avatar
wgotthardt
Sounds to me like you have the popular stop/start slip yoke 'clunk'.
https://www.ford-trucks.com/forums/4...ighlight=clunk
Old Feb 2, 2007 | 04:17 AM
3-RANGERS's Avatar
3-RANGERS
Hi ahall8, Consider checking your transmission mounts for broken rubber. Also consider servicing the transmission. Filter, fluid and such. You may not know how many miles are on the tranny but at least you'll know when it was last serviced. This will give you a chance to see if there are any foreign products in there too. All in all... I am also leaning toward the slip yolk clunk with "wgotthardt". Joe
Old Feb 2, 2007 | 04:19 AM
3-RANGERS's Avatar
3-RANGERS
Oh, I forgot to ask you...Do you have disk or drum brakes in the rear?
Old Feb 2, 2007 | 07:27 AM
ahall8's Avatar
ahall8
I have rear drums. Thanks for the idea. Thats why I am hear. I'll probably change the pan and filter because it never hurts to take a look, but I'll also consider the slip yolk thanks a million.
Old Feb 2, 2007 | 09:14 AM
3-RANGERS's Avatar
3-RANGERS
Arrow
Seeing IS believing. But remember, Believe nothing that you hear and 1/2 of what you see. Let me know what you find. Hey, keep your nose open for a smell of burned fluid too. Joe
Old Feb 2, 2007 | 10:34 AM
l-m tech's Avatar
l-m tech
try this part # at your locl ford store.. 5L3Z-19A506-A. this is the slip yoke grease that is suppose to fix the slip bump you feel when the truck comes to a rest.make sure you dont get the drive shaft out of phase when disassybling it.
Old Feb 2, 2007 | 05:51 PM
wgotthardt's Avatar
wgotthardt
I'm convinced that once the 'clunk' starts you are better off just replacing the part...I pulled my driveshaft off twice and lubed (once with the Ford spec grease, once with a thicker synthetic), both times it lasted less than a week. I then finally replaced the front yoke (and used the Ford grease), no 'clunk' since.
thisisbeer
Jul 30, 2013 06:52 PM
bwep
2004 - 2008 F150
17
Jun 12, 2009 12:13 PM
Double.g
Nov 18, 2004 03:30 PM
79CEEJAY
Jun 29, 2003 09:33 PM
F250_96_460_E4OD
May 30, 2002 04:46 PM
