Adjustable rocker arms
Old Feb 3, 2007 | 05:32 PM
rusty70f100's Avatar
rusty70f100
Yes. Mine were very uneven and they still adjusted fine.
Valve spring installed height will be messed up too, but that's not as serious a problem.
Old Feb 3, 2007 | 05:48 PM
390Highboy's Avatar
390Highboy
Sounds good. I think I'll check into this upgrade pretty soon. Thanks a lot for the help everybody.
Old Feb 5, 2007 | 11:06 AM
ranch67's Avatar
ranch67
you will have to adjust the rockers anyway with the lock nut. at that point, you will find the "slop" and turn 1/2 to 3/4 turn to lock down. you should have plenty of thread in the adjuster for preload.
Old Feb 5, 2007 | 11:25 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
To not have the proper assembled stem height will throw the rocker geometry out as well the pressure contact point on the valve stem, this will lead to more side force for more stem and guide wear than necessary. When a shop grinds valves they should of dressed the stems for the proper and equal stem heigth, should they be hardened tip and ground thru lash caps are installed.
Old Feb 8, 2007 | 04:35 PM
TG28's Avatar
TG28
which crane rockers did you have trouble with? i just got a set of the ductile adjustables but have not installed them yet. i also just got the edelbrock aluminum heads for my 390 has anyone tried this combination?
Old Feb 8, 2007 | 04:55 PM
"Beemer Nut"
That would be their roller tip aluminum rockers.
How many clams for your adjustable iron rockers?
I have a complete new set of TRW adjustable iron
rockers for another build project, purchased 'em
back in 86.
Old Feb 8, 2007 | 05:07 PM
TG28's Avatar
TG28
250.00 and i still need new shafts!
Old Feb 8, 2007 | 05:11 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
TG....the only one's I know that are affected are the FE shaft mount assy!! the complete set ready to mount...
The Crane Golds are still one of the top of the line in there price range...JMO
Russ
brandon mauldin
Sep 23, 2014 12:55 PM
mark1986F150
Dec 14, 2012 07:37 AM
seafire
May 3, 2010 11:40 AM
thunderb
Dec 13, 2007 01:45 PM
ford390gashog
Nov 1, 2004 09:27 PM
