Sponsored by: Auxito
compass/temp sensor
Old Jan 31, 2007 | 10:11 PM
428fourby's Avatar
428fourby
compass/temp sensor
Hi, Does anyone know where the compass/temp sensor is located on a 01 f-150?
I think mine is not working as the display started acting up a while ago, and know it doesn't work at all. Is there a way to test the sensor when find it?
Thanks
Old Jan 31, 2007 | 11:39 PM
Bluegrass 7's Avatar
Bluegrass 7
The sensor is located in front of the radiator top apron.
A short or open will cause the disply to read to either extreme.
If not lit at all the sensor may not be the problem.
If the compass works, the problem should be with the temp display only and may need replacement.
There are test procedures but it gets involved in trying to bring it all to the thread.
Check for voltages, fuse and dash dimming.
Old Feb 1, 2007 | 09:34 AM
MrBSS's Avatar
MrBSS
The most common problem is the display circuit board. Cracks develop in the copper traces due to thermal cycling, shock, or poor adhesion to the laminate.
They are very difficult or impossible to fix. You probably cannot buy just a new board from Ford, or if you can, it will be expensive. I would suggest getting an overhead console from a boneyard or e-Bay.
Old Feb 1, 2007 | 07:19 PM
tpgeneral's Avatar
tpgeneral
Hey guys I have a 02 king ranch, my display only shows a compass but has a select button. Are there features I'm misssing?
Old Feb 2, 2007 | 08:48 AM
KingRanchMan02's Avatar
KingRanchMan02
If your KR is like mine then you have EATC with the outside air temperature incorporated into the display for the heat and air conditioning controls and only the compass in the overhead console.
05F250DSL
Oct 20, 2013 08:17 PM
jim french
1997 - 2003 F150
Oct 20, 2011 08:43 PM
jbegler
Jan 13, 2010 12:21 PM
