1978 - 1996 Big Bronco
Final Decision --460
Old Jan 4, 2003 | 08:42 PM
big_beast302's Avatar
big_beast302
Okay, I have made up my mind to slap a freshly rebuilt 460 into my '82 Bronco. I do have a couple of questions though. First, originally having a 351W, I was wondering if I will need to change the motor perches in order to get the 460 to mount, or will the mounts from L&L or Advance Adapters work with the stock perches. Second, I don't want to take an engine just worked enough to properly breath and put manifolds on it. I was looking on Summit's website, and the only headers that I could find were Headmans and they were in the neighborhood of $375. Are there any cheaper headers out there that will work? I would preferably like shorty style headers. I'd appreciate any advice that you could offer.
Thanks alot.
Old Jan 5, 2003 | 12:05 AM
spixican07's Avatar
spixican07
if you're building a 460 go with full length headers. you'll get a lot more torque (i know..overkill...but why not?) and to tell you the truth i dont know if anyone makes any shorty's for it. not much of a market there.
Old Jan 5, 2003 | 01:13 PM
ryanguglich's Avatar
ryanguglich
The bellhousing are diferent you'll need another C6, Then the tailshaft-TC adapter might be longer that will screwup the drive shaft lengths and possibly mounting areas. I've heard the adapeter for motor mounts work well without any welding.
goodluck.
Old Jan 5, 2003 | 01:25 PM
efi460's Avatar
efi460
the L&L headers are expensive but very heavy duty - 1/2 inch mount flanges
but beware the "lifeitme" warranty is somthing like 3 years then pro rated to 50%
if you have a c 6 you will need a big block trans case
I got one at a junk yard and took the internals out of the sb case and put them in the bb case. I did a minor rebuild at the time.
The L&L mounts should work with your stock perches, I have read that if you can find the bb perches from an f250 you can use stock mounts
You will also need the truck/van oil pan.
Old Jan 6, 2003 | 06:12 PM
big_beast302
I have been looking for a set of headers from Hooker. From what I have read, they have some for this engine swap, but I can only find the ones for 78-79 Bronco's. If anyone has used these headers, where did you find them? Part number by chance? How much did they cost? Thanks again.
Old Jan 6, 2003 | 06:22 PM
sampsin's Avatar
sampsin
bsiebert
Jun 18, 2016 12:27 PM
mdlave
Feb 18, 2013 05:53 PM
CountryBumkin
15
Jun 26, 2012 04:43 AM
torquemeister
Engine Swaps
Jan 23, 2010 01:20 PM
roger dowty
Apr 19, 2009 10:56 AM
