Sponsored by: Auxito
electrical problem
Old Jan 31, 2007 | 02:05 PM
exyooper's Avatar
exyooper
electrical problem
Hi I have a 97 f150 4x4 auto while driving the speedometer comes on and off. The overdrive light comes on and off and so does the 4x4 light When I shut the truck off the heat blower comes on and will kill the battery Any idea's???
Old Jan 31, 2007 | 02:14 PM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE!
Sounds like water in your GEM module. This is the Generic Electronics Module, located behind the fuse panel under the left side of your dash panel. Water is getting in there from a windshield leak. Get that fixed first. Then if you are lucky you can take the fuse panel out and seperate the GEM from the fuse panel, dry it out. If there is no corrosion in there, put it back together. If corroded, you may have to replace both the GEM and the fuse panel. Good luck!
turbo930ss
13
May 17, 2013 12:36 PM
The Swamp
1997 - 2003 F150
Jan 8, 2012 09:37 PM
katruck
Nov 2, 2009 11:10 PM
Max1
1983 - 2012 Ranger & B-Series
Feb 15, 2007 03:15 PM
thullz
Dec 20, 2005 12:21 PM
