Does Rustoleuem REALLY Work?
Old Jan 31, 2007 | 11:26 AM
LARIAT 85's Avatar
LARIAT 85
I replaced my radiator this weekend, and when the radiator was out, I found quite a bit of rust and corrosion on the radiator brackets that are made into the frame. I scraped all the loose scale off, and used a product called "Rustoleum For Rusty Metal" from the hardware store and sprayed it on the infected areas. The can said that it would stop rust, and the guy from the paint counter claimed that it would stop rust in its tracks, but does it really? Has anyone ever used this product before? Will it really stop rust completely or just slow down the process some?
Old Jan 31, 2007 | 11:33 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I've had some really good results with rustoleum. It should definately help, if not completely eliminate the problem.
I dont think anything is 100%.
Old Jan 31, 2007 | 12:02 PM
srercrcr's Avatar
srercrcr
It's worked pretty good (but not perfect forever) on light rust for me, but big-time rust should really be removed/chemically treated to expect the best results.
Old Jan 31, 2007 | 12:24 PM
mark460's Avatar
mark460
I've used it for years on different stuff, but I usually remove at least the loose rust and sand or sandblast lightly and I've had good luck with the stuff. POR-15 is some good stuff to go directly on rust.
Old Jan 31, 2007 | 01:39 PM
robert steele's Avatar
robert steele
i just refinished a horse trailer used a hand ginder to remove the old paint and rust then sprayed it with rustoleum so far its good .as long as you get the rust of first and use a rust inhibeter and primer . remember its the prep work that is the life of the paint job.hope this helps.
Old Jan 31, 2007 | 02:17 PM
Franklin2's Avatar
Franklin2
I am a believer in the rusty metal primer like the counter guy you were talking to. It does stop the rust, and the only problem I have ever had is when I didn't get all the loose stuff off, and it fell off and took the primer coat with it.
Old Jan 31, 2007 | 06:37 PM
clunker86's Avatar
clunker86
where would you buy some pro 15 or some good stuff. i just removed my plastic kick plate by the drivers door and found i have a really good of amount of rust right there in the conner of the door fram and the floor. its starting to soften up in some spots. need something that is going to stop this in its tracks.
Old Jan 31, 2007 | 06:55 PM
SuperSnake's Avatar
SuperSnake
I wouldn't waste my money on POR 15. It's peeling away from the inside od my floorboards in my Dodge Truck it was also applied to the inside of the bed since it's not used to haul anything.
I used Rustoluem on the side rails and the top of my roof on my F250 after removing my camper shell after 2 years outside in all the weather we have here in NC it's still on hasn't peeled off at all.
Old Feb 1, 2007 | 10:59 PM
Pkupman82's Avatar
Pkupman82
I have had very good luck with Rustoleum paint products. I am doing a frame off resto/mod on my 84 F150 this winter. I used Rustoleum "Rust Reformer" on my frame after wire wheeling and cleaning it thoroughly. When the entire frame is done I will use the rust reformer as a base/ primer and then 2 or 3 coats of Rustoleum gloss black brushed on... I figure that should keep it nice for a very long time concidering the truck will be stored in the winter months.
Old Feb 2, 2007 | 12:34 AM
roger dowty's Avatar
roger dowty
Talking
I'm enjoying POR. My experience with rustoleum has been poor....unless all the rust is removed/killed and it sealed. I'd get the ospho to kill the rust left at least.
If the POR peeled off....how about the prep work? POR typically doesn't peel off. It's tougher than anything i've used. I've heard eastman makes good stuff for less.
remember you have to get both sides of the metal for anything to work- if it's spongy you might want to cut out the patch and weld. It's fun and really not that difficult unless you expect perfection.
Old Feb 2, 2007 | 09:21 AM
teds74ford's Avatar
teds74ford
The stuff I applied POR to has rust pinholes. The stuff I have done rustoleum on doesn't. I don't want to say one is better than the other, but in my experience, rustoleum works better.
That said, prep is still the #1 thing that makes a difference.
BigBlue2
Oct 23, 2016 08:22 PM
happscrap
Nov 22, 2014 04:04 PM
xjpilot
Dec 10, 2013 08:06 AM
biggreen78
Paint & Bodywork
Oct 25, 2004 01:17 AM
Ken2600
Oct 8, 2002 11:19 AM
