1978 - 1996 Big Bronco
Bronco dies...
Old Jan 7, 2003 | 12:46 PM
eel_kram's Avatar
eel_kram
Bronco dies...
Anyone have a cause/solution to this problem? Basically, it happens about every other time I pull into my driveway. The Bronco just turns itself off. This never happens while I'm driving or stopped at a light. It only seems to happen when I shift into Park. Any ideas?
Old Jan 7, 2003 | 05:21 PM
steve83's Avatar
steve83
Bronco dies...
ONLY when you shift to P; not in R? Only when the engine has warmed up? I see in your profile that it's an '88 Bronco - what engine & transmission??? Have you pulled the codes?
http://www.broncodata.com/tech/codes.htm
Maybe...
transmission malfunction locking up TC & stalling engine
vacuum modulator leak allowing trans fluid into engine, or vacuum leak
loose wires near shift linkage or in column
Old Jan 7, 2003 | 06:25 PM
eel_kram's Avatar
eel_kram
Bronco dies...
I haven't noticed the problem when I Reverse. It's a 302 with AOD(I have to check the tag). As for pulling codes... nope. Looks like I have a lot to learn. Thanks.
Old Jan 7, 2003 | 08:50 PM
steve83's Avatar
steve83
Bronco dies...
Well, with the AOD, there's no vacuum modulator, and it's almost impossible for it to lock up the torque converter at idle, so that narrows it down...
Old Jan 7, 2003 | 09:06 PM
honney's Avatar
honney
Bronco dies...
74 bronco
Kansas Chapter
256
May 9, 2012 07:37 AM
poor bronco
Aug 28, 2008 12:54 PM
ripsterone
Jun 19, 2004 09:58 AM
4whlnut
Jan 22, 2004 12:28 AM
GendoIkari69
Mar 18, 2002 07:22 PM
