1978 - 1996 Big Bronco
.......Electric Windows.......
Old Jan 2, 2003 | 12:00 PM
Brad18's Avatar
Brad18
Post .......Electric Windows.......
I've been having problems with my electric windows. It ranges from sticking briefly to just stopping all together. I've changed out the window motors several times and am wondering how i can prevent them from messing up. Is there anything I can do to extend the life of a window motor(and still use it often)?
Brad
Emissions Kill!
Old Jan 2, 2003 | 12:28 PM
CityBronco's Avatar
CityBronco
Spray WD-40 or some lubricant in the runners of the window. This will help it come down and go up easier and put less strain on your motors. This is what I have done and it works well for me.
Old Jan 2, 2003 | 04:03 PM
Lookinfurfun's Avatar
Lookinfurfun
Citybronco is on the right track, so to speak. The one problem is that WD40 is not a lubricant. Instead get some white lithium grease that you can spray on the window tracks. That should take care of the problem for you.
Old Jan 2, 2003 | 11:03 PM
craterjoe's Avatar
craterjoe
better yet and cleaner too, silicone lube ....
Old Jan 5, 2003 | 05:27 PM
SubmarineAZ's Avatar
SubmarineAZ
if it's the glass itself sticking in the track, you might try rubbing some Door Ease (Napa) around the glass. I used that on my rear window and it helped a lot and killed the squeak.
I think the tracks go down into the door quite a ways, and you can adjust them slightly by bumping them farther apart or closer together.
Old Jan 6, 2003 | 07:52 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Old Jan 7, 2003 | 06:42 PM
Dutch123's Avatar
Dutch123
Funny my electric driver side window froze up today. So, I should lube the runners to untick it? Could it be a fuse or some other crap?
Old Jan 7, 2003 | 08:49 PM
steve83's Avatar
steve83
The power windows are on a circuit breaker that resets automatically. It sounds like your motor is just worn out. Remans are about $80.
Old Jan 7, 2003 | 09:13 PM
Cheap Monster's Avatar
Cheap Monster
Mine was about $20 from a junker. Been there for over a year. www.car-part.com is your friend.
Diesel_Brad
114
Sep 14, 2019 02:12 AM
Supercab
Jan 1, 2017 08:07 PM
mscham
Jun 27, 2016 03:34 PM
cypressdelight
Apr 24, 2016 01:55 PM
Diesel_Brad
Large Truck
15
Mar 4, 2016 04:36 PM
