Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
frame q's
Old Jan 31, 2007 | 12:04 AM
preppypyro's Avatar
preppypyro
frame q's
Hey nathan, I was curious how hard all in all it was to do the frame for your truck? I have been contemplating getting this older merc i found, and trying to get the frame from my 77 for fit underneath. What is your opinion on this?
Old Jan 31, 2007 | 04:01 PM
51dueller's Avatar
51dueller
It's not terribly hard but it will be a slow process and will require a lot of space. I'm assuming this Mercury is a 1/2 ton and the 77 is a regular cab long box?
133" - 114" = 19" which isn't quite enough to eliminate the frame hump. So you will most likely have to mount your body 2-3" higher to match the box. You won't have to cut the cab however.
Now if you got the '68 F-350 frame from Snowking, then you would almost be ahead of the game. Just got to take the front and rear suspension from the 77 and bolt it on the frame. You will need to use the 77 front coil buckets since the 68 front coils aren't available anymore and too strong for your use. With the rear just swap in the rear leafs and hangers. The spring pads on the rear axle will have to be moved. The frame is already the correct width and it is totally flat which makes shortening it a breeze. 135" - 114" = 21 which have to be removed.
I was originally planning on using a '73-79 F-350 frame for my project but the 78 F-250 was tossed my way. Another note is the front track width is a lot wider. 59.5" to 66". The M-1 fenders just tuck the tires in. Hope this helps.
Old Jan 31, 2007 | 05:03 PM
Snowking's Avatar
Snowking
And I know Snowking would be willing to part with the frame, hey by the way your 49 Mercury, it still has the original drivetrain.right???
Old Jan 31, 2007 | 07:43 PM
51dueller's Avatar
51dueller
Well you just want the wrecker body. I didn't say you had to give it up for free...
Old Jan 31, 2007 | 08:26 PM
preppypyro's Avatar
preppypyro
Sweet thanks nathan. And yeah snow it has the original drivetrain, jsut hammering out a price now for the truck
newguy399
22
Mar 29, 2013 06:45 PM
54fever
Feb 22, 2005 06:09 AM
mallard8767
Appearance & Dress-Up
Dec 21, 2004 11:29 AM
blueoval429
Dec 14, 2004 02:40 PM
Nick8564
1983 - 2012 Ranger & B-Series
Nov 12, 2004 06:25 AM
