98 Ranger Hesitation When Accelerating
Old Jan 30, 2007 | 03:28 PM
jayhawkfan's Avatar
jayhawkfan
98 Ranger seems to run fine at normal speeds, but when I accelerate, say to pass on the highway, I get a bad hesitation that pulses. Thinking of fuel filter, MAF, throttle body. Anyone with this experience have any recomendations?
Thanks
jayhawkfan
Old Jan 30, 2007 | 03:54 PM
97ranger xlt's Avatar
97ranger xlt
what size engine please?
Old Jan 30, 2007 | 05:39 PM
jayhawkfan's Avatar
jayhawkfan
I forgot 3.0L
Old Jan 30, 2007 | 05:55 PM
Bob Ayers's Avatar
Bob Ayers
Plugs and plug wires. If the plugs have been changed, and Bosch plugs were installed, The Bosch plugs will misfire like you described.
Old Jan 30, 2007 | 09:14 PM
jimdandy's Avatar
jimdandy
Another thing that will cause this symptom is a worn spot on the throttle position sensor. It is fairly common on high mileage vehicles or vehicles equipped with cruise control. It causes bucking, jerking, hesitation, etc., when accelerating from cruise. It will sometimes set a code, but not always. jd
Old Jan 31, 2007 | 08:50 AM
tomw's Avatar
tomw
A flaky TPS will also cause the trans to go out of converter lock-up for no apparent reason. A dirty MAF will generally cause accel problems from a standstill What does it do when climbing a loooooong hill, where it would be sucking up a lot of fuel for a relatively long time? (fuel filter flows .. just enough to fool you... but not enough to accelerate at speed...).. or a weak fuel pump.
tom
Old Jan 31, 2007 | 10:02 AM
sfcwoodret's Avatar
sfcwoodret
Also try cleaning the injectors.
Old Jan 31, 2007 | 10:58 AM
jayhawkfan's Avatar
jayhawkfan
tomw,
The only time I notice the hesitation is when i do hard acceleration at higher speeds.
I think I'll try the filter first. I have no idea when it was last changed but it's been at least 60K miles.
thanks for the input
DieselCamper
28
Mar 16, 2022 10:42 PM
ocomas16
1997 - 2003 F150
Mar 16, 2016 05:26 PM
smokehaus
Sep 13, 2015 05:47 PM
jds872
Aug 12, 2015 01:15 PM
daniele
13
Oct 19, 2011 03:36 PM
