lost key
Old Jan 29, 2007 | 06:30 PM
AFISHN's Avatar
AFISHN
Trailering
Unhappy lost key
Lost my last set of keys over the weekend for my 2000 Excursion 7.3 Diesel.
I figured no big deal-go to the local Ford dealer give them my VIN# or other unique info for the vehicle and outta there in 10 minutes.
WRONG!!!!
They said I need to have the car towed in so "they can access the chip"
Is this true ?
Is their another way I can avoid towing this beast into the dealer?
Any ideas-or suggestions appreciated.
Tom
Old Jan 29, 2007 | 07:12 PM
Stewart_H's Avatar
Stewart_H
Is this true ?
When you say your last set, I assume you literally mean, you have zero keys for the Ex. If that's the case, then yes, they need to access the PATS system in the rig in order to program new keys for you. Either them, or a locksmith properly equipped with the correct PATS reading system.
If you have one set, and are looking for a second set, you can either take it to the dealership, or a locksmith, and again have the PATS read so a proper code can be downloaded into a new PATS key.
If you meant last set of spares, and you still have at least two properly programmed PATS keys, then you can purchase a blank PATS key from anywhere (I get mine from ebay), have them cut for free at any hardware store, and then program them yourself using the two keys you already have.
Stewart
Old Jan 30, 2007 | 04:58 AM
AFISHN's Avatar
AFISHN
Trailering
Thanks for your comprehensive reply, Stewart....
Unfortunately,I lost the only spare(and was too darn lazy to get other keys made when I lost my set of keys in a canoe dunking last summer!).
I really don't want to tow the vehicle to the dealer..Do most locksmiiths(in populous areas) have PATS Reading Systems?
Old Jan 30, 2007 | 05:47 AM
1buzzbait's Avatar
1buzzbait
---food for thought!the next time ya go canoe dunkin,make sure ya lock the keys in the x-then you can use the door pad code to open vehicle, no lost or fried keys due to water ingestion
Old Jan 30, 2007 | 05:50 AM
LEVEL10's Avatar
LEVEL10
since you lost all of your keys that is correct. your in for a tow job.
but if you still had the 2 factory key sets your owners manual states how to program additional keys your self. i forget the number you can do.but the manual states how many more that way.
Old Jan 30, 2007 | 05:59 AM
AFISHN's Avatar
AFISHN
Trailering
Thanks for the input.
"wudda,coulda,shuda" I'll learn sometime
Nice website Level10
Old Feb 1, 2007 | 02:41 PM
Stewart_H's Avatar
Stewart_H
Most do, but call around first. In my area, the dealerships, as expensive as they are, still charge less than the locksmiths. However, I've had friends in other states tell me the locksmiths in their area are a lot cheaper than the dealerships.
Stewart
Old Feb 1, 2007 | 03:00 PM
AFISHN's Avatar
AFISHN
Trailering
My wife found a spare key.....
Drove the car to the Ford dealer in West Chester,PA to get spares
1 key/1 computer access $139.00 Gulp
Extra key $39.
Pretty hefty I'd say...but $178 for essentially 2 keys does not exactly sit right --
Old Feb 1, 2007 | 07:01 PM
Stewart_H's Avatar
Stewart_H
Now, check out ebay Item number: 220076136443 as an example of what you need.
Do an ebay search "Excursion PATS" and you'll get more options. Either way, buy a couple (I've purchased approx 10 PATS keys for my vehicles off of ebay, they all work fine) blank PATS keys, have them cut at a hardware store, then program them yourself and save a chunk of cash.
Programming a PATS key:
1. Place first already programmed key in the keyway. Turn the ignition from OFF to ON (RUN) without starting the vehicle, for at least 1 second and then switch to OFF.
2. Within 5 seconds, insert your second already programmed key in the keyway. Turn the ignition from OFF to ON (RUN) without starting it, for at least 1 second and then switch to OFF.
3. Within 10 seconds of turning the ignition lock cylinder to OFF, insert the new key into the keyway. Turn the ignition from OFF to ON (RUN) without starting it, for at least 1 second and then switch to OFF.
The theft indicator light should go on for three seconds, after which the key will start the vehicle. Repeat this process, from the beginning, for each new key to be programmed.
When I went to my local OSH to have the keys cut, sometimes I'd get a guy who knew what he was doing and he'd just cut the key for me. Other times I'd get a rocket scientist who didn't want to cut my key because when he tested the key in their little doohicky, it showed as the chip being corrupted. It took time explaining to the guy the key hadn't been programmed yet, so the chip was "blank" and that was why the test showed it being corrupted.
I had to stifle a laugh when the guy told me to program the key first, then he'd cut it. When I explained the key needed to be cut before it could be programmed, he gave me a blank stare.
Anyway, just find a place that will cut if for you for free, then follow the directions above and as long as you always have more than two, you'll never be in trouble.
Spend $12 - $15 bucks on two keys, plus shipping (overcharged), and it's a lot cheaper than $178!
Stewart
Old Feb 1, 2007 | 09:01 PM
carltonmason's Avatar
carltonmason
You Need two programmed keys to program a blank?
Hello Stewart,
I just purchased a 2001 X and the owner only had one set of keys and couldn't find the spare set.
If I read your programming instructions, it seems I would need at least two existing programmed keys before I could program a new blank one?
What if I only have one existing working key?
What is the least expensive/reliable way to get spares given I have only one key?
Thanks for the info,
Carlton
Old Feb 1, 2007 | 09:14 PM
carltonmason
I think I found the answer to my question by searching this forum
Stewart,
I searched for forum for an answer to the question I posed to you and believe I found the answer -- sorry, I should have done the search first.
It seem to reprogram the key myself, I do indeed need two working programmed keys to begin with.
The post I found via the forum search gave a few alternatives.
Seems I'll have to make trip to the ford dealer to get it programmed.
I wonder if buying the OEM PATS blank on e-bay would be cheaper then the one sold by the dealership?
Thanks,
Carlton
Old Feb 1, 2007 | 10:20 PM
JAY95gt's Avatar
JAY95gt
Find a buddy in a Ford service dept. New key cost me $40. ($25 for the key and $15 for his "trouble." )
Interesting thing is he had the key made by the VIN and had it ready when I showed up to program it. It doesn't look like my current key, but BOTH work fine in door locks and the ignition but the new one doesn't work in the tailgate. Weird, huh?!
Old Feb 1, 2007 | 11:33 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by carltonmason
Stewart,
Heck Carlton, you didn't have to do a search, post #2 in this very thread has that answer for ya!
You can try and take the dealership your own blank, already cut, to be programmed. But they may refuse to use it, citing some BS reason, because they want to make more money off of you by making you buy their overpriced blank.
Stewart
Old Feb 2, 2007 | 07:01 PM
LEVEL10's Avatar
LEVEL10
i'm very sorry for this late THANK YOU about the web site. our web site is still under construction with much more help full information to be added about all car and truck brands.
time wise we have been very busy doing a few magazine write ups "mustangs and fast fords and diesel power" and super charging a mustang v6
Old Feb 2, 2007 | 07:05 PM
LEVEL10's Avatar
LEVEL10
Extra key $39.
dosn't sit right is correct.just be thank full you didn't have the key with every thing in it. that one is $139.00 by it self.
please now do your self a favor by getting two more cut and following our owners manual on how to code them your self and store them safely just like i had to do for our shop car.
wburge
6.4L Power Stroke Diesel
May 27, 2020 11:15 PM
Jimmyskalla
Electrical Systems/Wiring
Nov 7, 2016 02:32 PM
perryg114
Sep 24, 2012 01:51 PM
karatejody
Apr 17, 2009 01:33 AM
Nick37
1983 - 2012 Ranger & B-Series
24
Jan 12, 2007 01:08 PM
