Help Identifying Transfer Case
Old Jan 28, 2007 | 08:53 PM
erikkloss's Avatar
erikkloss
I bought a bunch of new OEM Ford truck parts from a company that sold off their fleet. All the parts are supposed to be for the 87-96 F series trucks. They all have the Ford part numbers, but this BW transfer case only has this info:
part number 1756-000-002. Can anyone tell me what it is supposed to fit. It is new "old stock". I haven't been able to find anything on the net.
Old Jan 29, 2007 | 09:18 AM
gustang818's Avatar
gustang818
Did the tag look like this? http://www.wildercafe.com/fordtech/images/xxTAG.jpg
Old Jan 29, 2007 | 09:36 AM
95Ford4x4's Avatar
95Ford4x4
tag is broke off on my 13-56, but if you look at the casing, front side between tranny hookup and front driveshaft mount, it is cast into the housing, borg warner and underneath should say 13-56 or possibly 13-45
Old Jan 29, 2007 | 03:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation
You need to find a: Ford# to Vendor#/Vendor# to Ford# cross reference book.
Basic Ford part number for a T/C Assy is: 7A195
This info can be found in select Ford parts books/microfiche (and current Ford books on CD & DVD).
Your local Ford Dealer's parts dept has these refs.
I checked the only one I have 1973/79: Found nothing, sorry.
Old Jan 30, 2007 | 07:49 PM
erikkloss's Avatar
erikkloss
Thank you for the help everybody. Here is what I have. The steel tag on the transfer case says C2892 and 1756-000-02 and 15' 20. There is also a paper bar code that says 1756-02. There are several casting numbers that start out with 13-56. I had heard that the 1756 was an improved 1356, but I have no idea if this is true. Does anybody know what this transfer case is? It is manual shift. I have photos, but can't figure out how to post them.
Old Jan 30, 2007 | 08:11 PM
andym's Avatar
andym
It sounds like a BW 13-56 by the casting numbers you have. I have no idea what a 1756 is, though.
Old Jan 30, 2007 | 11:03 PM
erikkloss's Avatar
erikkloss
I did a search for 1756 on this site and I came up with this very old thread:
www.ford-trucks.com/forums/94171-transfer-case.html?highlight=1756
I am still a little confused as to the application of the case. Is this supposed to fit the 87-96, or is it a specialty application? This is a manual shift case.
Old Jan 31, 2007 | 06:00 PM
gustang818's Avatar
gustang818
Ford transfer cases generally have a 6 bolt mounting flange. If it has that it should bolt up to any of the 4wd transmissions with the 6 bolt tailshaft housing.
I would also guess you have a BW1356. This catalogue has exploded diagrams of Ford transfer cases on pp 197-225. Maybe you can match up what you have with one of the pictures?
Old Jan 31, 2007 | 06:25 PM
andym's Avatar
andym
From reading that thread, it seems likely that the 1756 is an updated replacement version of the 1356.
Old Jan 31, 2007 | 06:26 PM
erikkloss's Avatar
erikkloss
I would like to look at that catalog to see the views. What catalog are you refering to?
Old Jan 31, 2007 | 07:54 PM
mjb1962's Avatar
mjb1962
erikkloss
You emailed me about the 1756 case ID. I had purchased what I thought was a 1356 case with a fixed rear output yoke from a distributor. The case had a lot of backlash so I contacted Borg Warner directly. I dealt with one of thier engineers about the problem. He agreed to send me a case with the backlash spec verified and I sent him the bad one. The invoice from Borg Warner called it a 1756. The metal tag also had 1756 stamped on it. From what I learned from Borg Warner, the 1756 is the same as a 1356 except for the fixed rear output yoke. This is how their numbering system differentiates between the different styles. I installed the case in my 89 F150 with the AOD transmission. Hope this helps.
Old Feb 1, 2007 | 07:27 AM
gustang818's Avatar
gustang818
Sorry about that. I was doing three things at once and forgot to paste the link:
http://www.worldamerican.com/Catalog...s_Tcase_LD.pdf
frank washington
Nov 7, 2016 10:44 PM
cwells1106
Oct 7, 2016 11:09 AM
ldgamblin
Missouri Chapter
19
Sep 22, 2015 05:52 PM
TFR
Jan 25, 2005 12:39 PM
nike_z
Mar 26, 2003 03:33 PM
