Bronco II Ford Bronco II
Pulling hair out. . . .please help
Old Feb 23, 2007 | 11:17 PM
  #46
kernel-panic's Avatar
kernel-panic
And do you know how many times I've seen ASE Certified mechanics screw up? Everyone is human. People do make mistakes. I don't know about anyone else, but my energy is lost on this one.
Old Feb 24, 2007 | 07:31 PM
  #47
73f100shortbed's Avatar
73f100shortbed
I thought it was impossible to put distributor in backwards after checking 5 times with 2 mechanics where i work on a truck once we checked TDC like 50 times and wound up being wrong. Always worth a double check even if you are certified. Everyone could make a simple mistake no matter what they know. I would also recheck your grounds.
Old Mar 25, 2007 | 11:46 PM
  #48
dirtybroncoii's Avatar
dirtybroncoii
well sorry about the delay i have been so busy i don't know what way is up. well i have been able to pull some codes
12 and 222
Old Mar 26, 2007 | 02:08 PM
  #49
kernel-panic
12 - Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low) - ISC
22 (I wouldn't think it's 222?) - MAP (vacuum) or BARO signal out of range - MAP
222 (found 3-digit codes) - (M) IDM open or high or right coil pack failure - Ignition Systems <-- this points to what I would think is a EDIS ignition, not a TFI ignition??
Hope this helps
Old Mar 26, 2007 | 09:11 PM
  #50
dirtybroncoii
well before actually checking my KOER codes i have to replace my flywheel. I moved my ground a while ago and it caused my starter to break and then screwed up my flywheel. so ill keep you posted.
Old Mar 26, 2007 | 09:34 PM
  #51
kernel-panic
Ouch, sorry to hear about the starter/flywheel situation. That's not fun at all.
I'd lean more towards the IAC being the issue, as well as the MAP (it's known to happen, and having both being screwy, makes it worse). The good-old tempermental cold-natured Ford thing, so to speak. I have a similar situation, but it's probably a combo of the IAC and needing to re-adjust my idle stop. I've noticed sometimes, when I let the truck warm up for 5-10 minutes before driving it, it doesn't do it as much. *shrug*
Let us know how things go after you get the flywheel fixed
Old Mar 26, 2007 | 09:45 PM
  #52
dirtybroncoii
Well i have noticed that too
"I've noticed sometimes, when I let the truck warm up for 5-10 minutes before driving it, it doesn't do it as much."
Mirage
1983 - 2012 Ranger & B-Series
Mar 16, 2017 05:50 AM
Jarrard7
Jul 20, 2016 04:26 PM
Barrakuda
May 25, 2016 04:52 PM
Amarillo_Ranger
Feb 19, 2016 06:36 PM
Gordon Freeman
Feb 6, 2014 07:03 AM
