Need help with engine bog problem
Old Jul 19, 2016 | 01:09 PM
Jarrard7's Avatar
Jarrard7
I have a 1988 f-250 with the 5.0/302 efi and I have had problems lately with my engine. So the problem is that while sitting idleing if I step on the gas it hesitates and misses just a small amount but for as when I'm driving say I drive around and then come to a stop sign as I let off the clutch in 1st it bogs down and I have to feather the gas so it won't just shut off and same thing in second gear but after I get to 3rd it clears out so in 1st and second under 2000rpms it bogs coming off the clutch and after driving around for say 20 min it'll just shut off and wont want to start again but say I wait a day it'll start first time no problem I've gotten a new fuel pump replaced the Ecu and the o2 sensor and my fuel pressure is where it should be.
Old Jul 19, 2016 | 09:17 PM
xlt4wd90's Avatar
xlt4wd90
Did you try changing the fuel filter?
Other possibilities include the throttle position sensor. You can test it with an analog ohm or volt meter by hooking its leads to the wiper and one side of the variable resistor. The resistance or voltage should change smoothly as you open and close the throttle. You test the resistance by pulling off the EEC connector, and test the voltage with the key ON engine OFF. Either one should be able to tell you if you have dead spots on the sensor.
Old Jul 20, 2016 | 02:03 PM
Jarrard7's Avatar
Jarrard7
I have replaced my fuel filter. And alright thanks I'll try to do that today
Old Jul 20, 2016 | 04:26 PM
rla2005's Avatar
rla2005
Your 1988 F250 has electronic fuel injection that uses a computer. Run the KOEO tests and stored code display. See what it thinks is wrong.
There is a CM code for an erratic or missing PIP signal. hint:"after driving around for say 20 min it'll just shut off and wont want to start again" Classic bad PIP symptom, but do the diagnostics first. Obviously throwing parts at the problem has not fixed it yet.
Jarrard7
Aug 19, 2016 11:18 AM
Jarrard7
Aug 12, 2016 08:29 PM
dirtmonkey11
Jan 21, 2010 10:06 AM
PhatCaprice
Jan 13, 2004 02:42 AM
tite4x4
Computer Chips & Tuners
Mar 7, 2003 11:02 AM
