1978 - 1996 Big Bronco
welding ttb to make it a solid axle?
Old Jan 6, 2003 | 02:14 AM
greystreak92's Avatar
greystreak92
To all those who dislike the TTB/TIB suspension, best of luck in your quest. For those of us who like it, We will keep our smoother ride and not lose sleep over it. TTB/TIB trucks for having such a "bad" suspension system under them are still the truck and suspension type of choice for many Baja and sand racers because of the incredible wheel travel you can get from it. I believe BAJA regulations limit trucks to 15" of wheel travel but getting 19+ from a TIB is not unheard of. Autofab.com is a prime testament to the TTB considering with their mods, even a TTB truck can acheive 16" of wheel travel. Not bad for such a "bad" idea.
Old Jan 6, 2003 | 08:13 AM
honney's Avatar
honney
>>TTB suspension is a bad idea in general.
>I guess Ford engineers just stuck it under every fullsize
>half-ton for nearly 15 years because they figured they could
>get away with a "BAD idea"!
That's true actually. Ford put a lot of work into TTB, and didn't want to change. Besides, it was cheaper to keep doing the same old thing once on that track. It's the same way Ford managed to build Broncos with rain gutters that crack for 16 years, and dist mounted TFI modules that fail for what.......10 years or so throughout the entire Ford line-up (incl cars)??
Just because a vehicle manufacturer does something for 16 years does not mean it's a good idea........
Old Jan 6, 2003 | 08:14 AM
honney's Avatar
honney
>It wouldn't be hard to add a track bar, but probably even
>easier to convert to leaf springs like the heavier TTBs use.
> You KNOW leaves can hold the axle in place - they obviously
>do on the REAR axle!
Steve's right. It makes much more sense to do this with D50 TTB like this guy did:
http://members.aol.com/_ht_a/jzettel73/TTB_Conversion.html
Old Jan 6, 2003 | 08:16 AM
honney's Avatar
honney
>I thought about putting leafs under my 78 Bronco, but the
>work that you would have to get involved in just isnt worth
>it.
Your '78 is the easiest of all to get front leafs under. Get the hangers from any '77ish F250 and it's nearly a bolt-on deal. You do have to box the front framerails and burn a hole for the rear shackle pivot.
But you're right - the issue becomes the steering arm clearing the leaves with those stupid Sag boxes mounted outside of the framerails. So steering will take some creativity and almost surely a different box.
Old Jan 6, 2003 | 08:20 AM
honney's Avatar
honney
Have you driven many different kinds of solid axle trucks? For most uses the "smoother ride" thing is a myth. My leaf sprung SAS rides every bit as good as my old TTB, and handles better to boot.
You're right - the only application where TTB makes sense is in the desert, but keep in mind their TTB is nothing like what you drive daily......and those guys don't have to worry about tire wear due to bad camber and all the TTB alignment nightmares as they're rarely on pavement.
Old Jan 6, 2003 | 06:55 PM
Johnny88Bronco's Avatar
Johnny88Bronco
I guess this discussion is about wrapped up, and the only thing discovered, just like a))()s everyone's got one. Ha ha, thanks for all the input
Old Jan 15, 2003 | 06:35 PM
mooktank's Avatar
mooktank
im doin it in a few weeks as soon as my dad brins ohme an arc welder. im gonna make a track bar and just use all custom made parts instead of buying all this other crap. hopefully it will be cheap and easy. Im just going to get two of those alignment levels and get them completely strait and weld her up. Just so you know the only reason im doing it is because im poor now after lifting my truck and putting on tires and this camber issue is really pissing me off.
Old Jan 15, 2003 | 07:01 PM
mrwizard's Avatar
mrwizard
rowdyredneck
Nov 20, 2016 02:04 PM
ranger_
33
Oct 19, 2016 09:04 PM
wa-sleeper
Feb 5, 2016 04:24 PM
Willz74
16
Aug 16, 2015 08:57 PM
OffRoadF-150
Offroad & 4x4
43
Jan 2, 2006 01:10 AM
