Help me identify this plug...
Old Jan 27, 2007 | 08:44 PM
genovet's Avatar
genovet
What is this female plug next to my IP?
Old Jan 27, 2007 | 08:47 PM
KJLYPW's Avatar
KJLYPW
I believe that would be for the tach sensor which would normally go into the big plug you have there on the bottom right side of the picture, (drivers side of the IP gear cover).
Old Jan 27, 2007 | 09:41 PM
DNewton's Avatar
DNewton
yes, if your talking about the the plug were the "2" is in 2007, that is wear the tach sensor would be mounted if you had a tach..
Old Jan 28, 2007 | 12:38 AM
crazymike's Avatar
crazymike
cant tell you what it is. but in our taurus there is aty least 6 plugs that arent plugged in and it's fine
Old Jan 28, 2007 | 11:26 AM
Dave Sponaugle's Avatar
Dave Sponaugle
The black plastic plug is for the tach sending unit electrical connection.
Looks like this when you have a tach installed.
Old Jan 28, 2007 | 11:28 AM
genovet's Avatar
genovet
I'm interested in putting a tach in my truck so I was hoping that the female plug in the picture was in fact for the tach sensor. Since it appears that I have the tach wiring in place it would now just be a matter of purchasing the tach sensor and an instrument cluster with the factory tach and I should be in business. Seems too easy. How much does the tach sending unit cost?
Old Jan 28, 2007 | 11:43 AM
PLC7.3's Avatar
PLC7.3
Ford only part about $50...
RPM sensor Part number is E5TZ-17B384-A
Old Jan 28, 2007 | 12:01 PM
genovet's Avatar
genovet
Not bad at all...my local Ford dealer gives me a discount on top of that which makes it even better.
Now I need to locate a '80 - '86 diesel instrument cluster w/tach for an automatic. If anyone has one let me know.
Old Jan 28, 2007 | 01:03 PM
Dave Sponaugle
Even though the wiring is in place, the insturment cluster on a non tach truck does not have the wiring circuits to install a tach.
All this means is you must swap the entire insturment cluster into your truck.
Salvage yards are the only sorce for the insturment cluster, Ford has discontinued the tach and cluster.
Once you have the cluster, it is a plug and play swap though, plug in the cluster, plug in the sensor and you are ready to play.
I just had a thought, LMC may have the cluster, I never looked.
matts156
26
Mar 12, 2014 11:02 PM
97flairside
1997 - 2003 F150
Apr 16, 2011 06:57 AM
G2IC_Wraith
Electrical Systems/Wiring
Mar 26, 2007 08:47 PM
