ICP sensor
Old Jan 27, 2007 | 02:39 PM
7117's Avatar
7117
ICP sensor
Have 96 F250 and fuel is leaking from what I think is ICP. Looks like oil sender on SBC. Parts stores do not carry. Is this dealer only? Anyone with a part #
Thanks
Old Jan 27, 2007 | 04:31 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Thanks
Which sensor is it? The ICP would only have oil leaking from it.
Old Jan 28, 2007 | 10:45 PM
7117's Avatar
7117
The fuel is dripping from the 9F838 ICP.
Old Jan 28, 2007 | 11:04 PM
ltfox's Avatar
ltfox
Their is no fuel in the ICP, Only high pressure oil.
Old Jan 28, 2007 | 11:23 PM
smuzz's Avatar
smuzz
Please go and look at the pictures in this gallery
https://www.ford-trucks.com/user_gal...?albumid=20704
I can't remember the technical name for it but it is a called a vacum switch I think. I have had two leak you can plug it off it till you have time to fix Is a dealer only part I believe. Sorry for no part number if that is your problem.
Old Jan 29, 2007 | 09:42 AM
plowhand's Avatar
plowhand
Playing in the Dirt
smuzz, that is the vacuum switch located on the side of the FPR, which is located on the side of the fuel filter housing, it also is a one wire connector.
7117 the ICP which is located front, inboard, on the left head (drivers) has a three wire connector and screws into an oil passage.
Old Jan 29, 2007 | 01:06 PM
7117's Avatar
7117
PLOWHAND thank you for clarification on that. SMUZZ thank you for picture. The part is a restriced fuel filter sensor # E8TZ9S283-A about $50 from ford. Thanks again for your help.
Old Jun 30, 2011 | 12:04 AM
amickr's Avatar
amickr
ICP sensor
Hi I am looking for an ICP sensor any Ideas on where I can find one
Old Jun 30, 2011 | 12:18 AM
BuckHammer's Avatar
BuckHammer
Wow, you resurrected this old thread.
Try Partsguyed or RockAuto.
tahiti429
Oct 29, 2015 04:22 AM
bulldog88
17
Feb 14, 2015 06:41 AM
Snuggyworm
Jan 6, 2014 09:31 AM
Misn 1
Oct 5, 2013 09:38 PM
Byrddog
Mar 18, 2012 04:23 PM
