96 Windstar P0733 tranny code.
Old Jan 27, 2007 | 08:27 AM
LxMan1's Avatar
LxMan1
Exclamation 96 Windstar P0733 tranny code.
Yesterday my tranny started intermittantly started Shifting from 2 to three, then back to 2 and then throwing the P0733 code. I know why it's throwing the code and since it's not throwing a solenoid code, I am guessing something in the valvebody is sticking or not moving properly. It doesn't do it all of the time.
Has anybody had this happen and what actually fixed it?
This van has a lowered floor to haul my son in his wheel chair and I can't have it leaving us stranded somewhere.
Old Jan 27, 2007 | 08:07 PM
Racerguy's Avatar
Racerguy
Jimmy I asked our transmission guy at work about the code. He says the most common thing he's seen is an internal problem, probably not a valve body problem
Does it actually go into 3rd gear or does it try but there's nothing there for it to go into so it goes back to 2nd?
Old Jan 27, 2007 | 09:45 PM
LxMan1's Avatar
LxMan1
It goes into 3rd for a second, but then shifts back. It doesn't do it all of the time. It seems to be worse it you accelerate real easy. After it does it, if you come to a complete stop, then take off again, it acts fine. I am going to change the fluid and filter Monday morning after work to see if this helps and to see how much debris is in the pan.
A guy from our local drag strip that has a tranny shop told me that he would pull it, rebuild it, and reinstall it for $1500.00. He said it's usually $1800 to $2200 to do one, so if it needs rebuilt, I'll have him do it.
Old Jan 29, 2007 | 01:55 PM
LxMan1's Avatar
LxMan1
Well, I changed the fluid and filter. There was some debris on the magnet, but not any more than I would suspect in 151,000 miles. Not really thick, just enough to cover it.
It appears that it is slipping in 3rd gear now that I have drove it more. But, it only does it under light throttle conditions like in a neighborhood. Anything over about 1/4 throttle, it doesn't act up, but on light acceleration, once it starts slipping, it won't catch up with throttle until you either slow down and accelerate harder in 2nd, then it goes into 3rd and pulls fine. I am starting to think that it is in the valvebody and perhaps the 2-3 shift valve is sticking on light acceleration.
Any thoughts on that Dave? I guess I'll run it by the tranny shop tomorrow. I've been up about 24hrs now and I gotta get some sleep.
At least the new belt tensioner that I put on today cured the squeaking noise at an idle. Something went right today.
Old Jan 29, 2007 | 11:38 PM
Racerguy's Avatar
Racerguy
I would have the transmission shop test it properly with line pressure gauges etc.
Unfortunately older Windstar transmissions don't have a very good track record and once they start slipping they are usually due for a rebuild
Old Jan 30, 2007 | 06:42 AM
LxMan1's Avatar
LxMan1
Yeah, I've read that on the web. I guess I am lucky getting as many miles out of it as I did. I'm taking it in this morning.
Old Jan 31, 2007 | 07:27 PM
LxMan1's Avatar
LxMan1
Well, tranny guy say's it's definately a valvebody issue, but with the miles on it, I told him to go ahaed and rebuild it. I'd hate to sink the money into it and then the clutches go out a few months later. So he is pulling it tomorrow.
Old Jan 31, 2007 | 09:31 PM
Racerguy's Avatar
Racerguy
With 151,000 on it you've done well with it.
Sounds like a rebuild will be good insurance.
Old Jan 31, 2007 | 09:53 PM
LxMan1's Avatar
LxMan1
I thought so too. What scres me now is that it still has the original head gaskets on it. That's a long time for a 3.8L. It uses no oil and runs strong, so maybe it will last a few more years. I would buy another one, but it's hard to find a Ford with a lowered floor and a ramp for a wheel chair. Most are Chrysler/Dodge and I don't want that headache. A good low mile used van like mine goes for around $35,000+.
Old Jan 31, 2007 | 10:36 PM
Racerguy's Avatar
Racerguy
Now that Ford is stopping making minivans they will probably get even harder to find and more expensive.
If another one costs $35k I think I'd be hanging on to what I've got even if it meant putting a few thousand into it.....as long as the rest of it is in good shape.
I've worked on a few Windstars with tons of hard miles on them and they still keep on ticking. Other than transmissions and head gaskets on some of them they really are pretty tough.
Old Feb 1, 2007 | 12:21 AM
LxMan1's Avatar
LxMan1
I will probably do that. All I've reall ever done to it is 1 waterpump, 1 belt tensioner, 1 fuel pump, brakes, shocks and tires. It's been a good van so far.
We we sold out 89 Aerostar, it had 249,000 miles on it and ran like a new one. We went thru 2 crappy A4LD trannys in it, but it never used oil or anything. Those 3.0 engines are bullet proof.
I've done the head gaskets on a couple of T-Birds (3.8), It's just a bit tougher when the motor sits sideways and I have to remove the cowl to access things (even to change the rear plugs.
Old Feb 7, 2007 | 02:23 PM
LxMan1's Avatar
LxMan1
Just an update, He is building the tranny today. It needed a new pump, drum assembly and he is replacing all of the solenoids and such in the valvebody. He is also doing all of the upgrades that have come over the years since 96. It should last a long time I would hope. He's doing it all for $1600.00 which sounds fair to me. Hopefully I'll get it back this evening, if not tomorrow.
He also mentioned that there was an update kit for the upper intake and front valvecover to prevent oil leakage. It's a couple of hundred dollars at the dealer. I really haven't had any oil consumption so I'm not going to do that right now. He said that he would have installed that free (labor) since he had to pull the plastic upper intake to attatch the hoist to hold up the engine while the tranny was out.
I guess I'll do that upgrade when the head gaskets go.
Old Feb 18, 2008 | 04:11 PM
JoAlexan's Avatar
JoAlexan
'98 Windstar, Missing 3rd
Racerguy: You asked if the tranny was going into 3 and back out or acting like there was nothing in 3. I Have a '98 windstar that today has lost 3rd. There is nothing there. If I hold it in 2nd to 50Km then it will go from 2 to OD and I made it home.
Is this likely fatal?
Old Feb 18, 2008 | 04:35 PM
Racerguy's Avatar
Racerguy
Welcome to the forum JoAlexan
Unfortunately usually when you lose a gear completely it is fatal. At this point I would probably take it to the dealer and have it checked. They can check line pressures etc. to hopefully get a better idea what happened before tearing it apart. Windstar transmissions aren't the best transmission Ford built. I'd be thinking about putting in a rebuilt.
Bringthepayne18
24
Aug 17, 2017 06:18 PM
Rich7944
1983 - 2012 Ranger & B-Series
Aug 11, 2015 01:11 PM
rennat
Feb 28, 2015 07:27 PM
Joe28443
Apr 24, 2010 04:25 PM
pinheads52
Dec 15, 2009 12:01 PM
