p0733
Old Apr 23, 2010 | 03:01 PM
Joe28443's Avatar
Joe28443
Joe28443
p0733
well it looks like a possible new tranny coming soon. I got this code the other day and took it and had it scanned. It has something to do with 3rd gear. I then took it to a tranny guy and I told him my code and he said " thats not good" He scanned it for me also after the first time it was cleared and it did not show the code. He asked me if the overdrive light was blinking and it has not been. It runs good shifts fine and acts normal. The code is not on now. Is it possible its just a fluke and its not a real big issue or is my 3rd gear getting ready to fall out from under me? I told him I was getting ready to hook up my TT Sunday and be gone for a few days. He asked if I wanted to make an appointment next week for a new transmission. I am going to drive it till it busts, I have AAA. So does it sound like a computer issue or a mechanical problem? I asked the tech about the diode it being a 2001 and he said the diode is for the 2nd gear not the 3rd
Old Apr 23, 2010 | 03:50 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If the code didn't come back, I would not worry about it, unless you start feeling something wrong. You do have the dreaded '01 trans with the Diode. I had the same thing untill I went to BTS a couple weeks ago and had Brian build my trans.
Old Apr 23, 2010 | 04:02 PM
Joe28443's Avatar
Joe28443
Joe28443
BTS sounds good but may be a little more than I could stand. My guy tells me he can rebuild mine beefed up to quote " haul the mail" and that I would not have a problem with it for 2500.00 which sounded like a deal but also sounded cheap. I don't plan on going to extreme with the X. Maybe a small tuner and will be hauling a 6500 TT.
Old Apr 24, 2010 | 10:40 AM
PaysonPSD's Avatar
PaysonPSD
Just thinking out loud. There are 2 sensors on the tranny. A TSS (Turbine Speed Sensor) and an OSS (Output Shaft Speed) that the PCM uses to determine the difference in the input speed and the output speed of the tranny to determine the ratio. One of the sensors could have had a glitch and the PCM didn't see the proper ratio when in third gear and set the 0733 code. If the code comes back I would replace one of those sensors. They should be interchageable so you would only need one to find out if either one is bad.
Old Apr 24, 2010 | 11:08 AM
Joe28443's Avatar
Joe28443
Joe28443
I'm driving around now and its shifting fine and the code has not come back yet. So maybe that's it. Let's hope so. Thanks
Old Apr 24, 2010 | 12:06 PM
PaysonPSD's Avatar
PaysonPSD
Has your OD OFF lamp ever started blinking? That is what usually happens when the PCM sets a tranny code.
Old Apr 24, 2010 | 01:21 PM
Joe28443's Avatar
Joe28443
Joe28443
No its never blinked. But if its going to it will do it tomorrow when I leave for vacation.
Old Apr 24, 2010 | 04:25 PM
PaysonPSD's Avatar
PaysonPSD
No blinking OD lamp is a good sign.
Now let's be a little more optimistic. But I know what you mean. That's how things go sometimes. But in this case I think you're good to go. Enjoy your vacation.
solareclpse2000
Jun 11, 2018 04:21 PM
TeamMudd
Modular V10 (6.8l)
Jun 3, 2017 04:54 PM
zoli
Modular V8 (4.6L, 5.4L)
Sep 19, 2015 12:10 AM
yitzy
Aerostar
May 8, 2012 03:48 PM
Paul Moody
Mar 5, 2012 07:10 AM
