bell housing help
Old Jan 26, 2007 | 03:47 PM
juchertf100's Avatar
juchertf100
Unhappy bell housing help
doing a motor swap from stock 240 to a not stock 78 302 bored 60 over
was told my manual bellhousing would work and it fits ok but i needed a new flw wheel and i found one on EBAY thought it was right but of course i was wrong it has 157 teeth so my question is can i get a diffrent starter and use this one or or do i have to get a bigger fly wheel or maby a diffrent bellhousing
any help would be great\
thanx paul
Old Jan 26, 2007 | 04:39 PM
FordBoypete's Avatar
FordBoypete
Paul,
I believe bellhousing is right.
Just get correct flywheel to fit engine you have. I don't believe amount of teeth determines flywheel size. In fact you may be able to just use a different ring gear, if balance is right on flywheel you have, for engine you have. I think diameters are fairly typical as in all the same among non SVO 302 and other 5.0L Windsors
The balance issue is more important than flywheel teeth IMHO. I'm not a big 5.0L or 302 fan so I might be wrong, but if I am somebody will set me straight.
FBp
Old Jan 26, 2007 | 04:41 PM
airharley's Avatar
airharley
According to the info I have found the 302 uses a 164 tooth flywheel as does the 240. You will need to get a different flywheel to properly mate the starter. Check out the link I posted comparing the some of the differences with flywheels.
http://lists.twistedpair.ca/pipermai...er/006195.html
The 157 tooth flywheel is for the 5.0/5.8 fuel injected windors. Swapping the starter might work but I can't say for sure. Check the Windor engine forum to see what they come up with though before you spend more cash.
http://www.quicktimeinc.com/products.html
Old Jan 26, 2007 | 05:04 PM
juchertf100
thanx air i will do that thanx for your help
paul
Old Jan 26, 2007 | 10:21 PM
mtflat's Avatar
mtflat
I've messed with more 302's than I like to admit sometimes. They use the same starter. If you think about it the starter bolts to the bell housing so the bell housing determines starter location. The flywheel needs to stick out far enough for the starter to contact properly.
There are two sizes of bell housing and also flywheels. 164 tooth flywheel measures approx 14.25" across and works with the wider/older bell. 157 tooth measures approx 13.25" and is used with the newer bells (generally) to mate with trannys like the T5.
Balance is also an issue. Prior to '81/82 an imbalance of 28 oz. was used. After 82 an imbalance of 50 oz was used. Keep the imbalance the same on the flywheel as on the harmonic balancer behind the crankshaft pulley up front.
From what you've described I'd say you're looking for a 164 tooth flywheel with 28 oz imbalance. to work with your bellhousing. Any junk yard should be able to set you up. If not check with supply houses like NAPA or Speedway.
Old Jan 27, 2007 | 08:30 AM
FordBoypete
Thumbs up
Mark & mtflat,
You guys did a great job explaining details of what I was trying to say, I 'preciate it.
I knew they all fit, but do not "interchange" or work correctly. I also know why that is, as we're all saying. What I don't/ can't remember is details like how many teeth & how many Oz's of balance weight difference there is.
I also just learned using both 28 Oz or both 50 Oz [flywheel & Harmonic balancer] on either Early or a Late "W" Engine. I didn't realize it was the remedy Hhmm? Interesting!
I know there are Nodular Cast steel Bellhousings & light wght cast alloy bell housings. If you plan to run a 351W that's been "prepped", go for a Nodular steel, as alloy is capable of breaking with a healthy shot of "bottle", or a big increase in displacement like the +390, +410 or +427 stroker engine options possible from a 351W block. But that's way too hi tech for this topic I s'pose.
FBp
Old Jan 27, 2007 | 10:08 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Maybe?
Also keep in mind he has a manual bellhousing and flywheel.
when swapping to newer fly wheel and harmonic balancer do not use the water pump from newer donor motor,
they ( turn backwards ).
P.S. just keep fly wheel and bell housing matched together or your starter
will not engage, was tought this at the school of hard knocks!
Wally Womack
Jeffrey Sutton
2004 - 2008 F150
May 10, 2014 05:48 AM
'83f3fiddy
17
Mar 23, 2010 09:25 PM
jstutz101
Aug 4, 2008 09:17 AM
trav69187
Nov 10, 2007 03:58 PM
crapr6
13
Sep 19, 2004 05:51 PM
