04 to 08 motor swap, p0174 code, help snow is comming?
Old 01-22-2013, 08:54 AM
Jeffrey Sutton's Avatar
Jeffrey Sutton
Jeffrey Sutton is offline
has anyone swapped a later model motor into there chassis, I swapped and 08 into mine and i cant get rid of the p0174 code. I have checked for vac leaks, swapped maf, intakes and replaced gaskets, o2 sensors, cats, replaced coils, done a fuel injector leak test, the bank one trim is good where the bank two lttrim is out at 30%, I've been hitting a brick wall and cant get around it. I asked my ? on that just answer site and the guy claims the cams are diffrent and is what is causing the problem? seems like it would do it on both sides.
Any ideas?
Old 01-22-2013, 08:23 PM
air1jpg's Avatar
air1jpg
air1jpg is offline
Did you swap the computer? Could there be a difference in the computer between a 04 and a 08 ?
Old 01-22-2013, 09:07 PM
Jeffrey Sutton
no the chassis i bought didnt have the pcm with it he took that when he swapped the body
Old 05-10-2014, 05:48 AM
Jeffrey Sutton
figured Id finally put the answer out there in case someone else comes along... Pcm and wiring harness were the same had a plugged catalytic converter
hmilycar
1983 - 2012 Ranger & B-Series
07-09-2015 11:11 AM
LaReko
1997 - 2003 F150
11-29-2012 12:55 PM
Reed
32
07-02-2010 10:53 AM
joeycyph56
1999 to 2016 Super Duty
08-18-2008 07:42 PM
almus
06-09-2007 01:49 PM
Quick Reply: 04 to 08 motor swap, p0174 code, help snow is comming?
