EBPV Temporary Fix
Old Jan 26, 2007 | 03:31 PM
marvinlong's Avatar
marvinlong
EBPV Temporary Fix
I need to wire my ebpv open since the actuator rod is broken. Looking from the passenger fender into the engine compartment, should I push or pull the valve open? Thanks
Old Jan 26, 2007 | 04:20 PM
sean23johnson's Avatar
sean23johnson
i used some wire and wraped it around the EBPV arm and then around the corner leg on the pedistal. pull it tight and secure it. make sure the valve is OPEN. i wish i had a pic but it is a little too difficult to get back there now.
Old Jan 26, 2007 | 04:23 PM
marvinlong's Avatar
marvinlong
I here what you're saying. So I should pull to make the valve open. Thanks
Old Jan 26, 2007 | 05:42 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
It should default to the open position when the engine is running, as the exhaust will keep the one side of the butterfly up against the stops as exhaust passes over it.
Old Jan 26, 2007 | 06:18 PM
Kwikkordead's Avatar
Kwikkordead
This picture might help.
Powerstroke_Steven
Jan 22, 2014 04:49 PM
A/Ox4
Apr 11, 2013 06:36 PM
matowns21
Jan 12, 2012 08:16 AM
BLACK F 350
Jul 22, 2006 12:39 AM
otpracer100
Dec 19, 2005 09:34 PM
