EBPV
Old Jan 5, 2012 | 07:48 AM
matowns21's Avatar
matowns21
EBPV
I was told that cold the ebpv would open to help the engine get warm. Is it normal for it to do it at normal op temp?
Old Jan 5, 2012 | 07:51 AM
DIYMechanic's Avatar
DIYMechanic
The EBPV CLOSES to help the engine warm up, and yes it is possible for it to malfunction and close while the engine is at operating temperature. Unplug the electrical connector and see if that doesn't stop the problem from happening. It is a little 2 wire connector under the intake side of the turbo. It won't hurt anything to run it unplugged, in fact quite a few (myself included) have deleted the EBPV all together.
Old Jan 5, 2012 | 11:08 AM
rockndb's Avatar
rockndb
is it worth deleting?
Old Jan 5, 2012 | 11:12 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Yes, better exhaust flow, less EGTs, better perfomance and less possibility of oil leak. But you can use it like a CHEAP exhaust brake
WELCOME a board
Old Jan 5, 2012 | 11:32 AM
matowns21's Avatar
matowns21
So to delete it you just unplug it?
Old Jan 5, 2012 | 12:26 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Nope, you only deactivate the function. To delete it you have to eliminate the butterfly in the exhaust housing and also you can delete the part that its integrated in the turbo pedestal where the rod its in.
Old Jan 5, 2012 | 12:40 PM
richdawg's Avatar
richdawg
The following link that is pretty clear on what is necessary to delete or gut the Exhaust Back Pressure Valve.
Gutting the Exhaust Back Pressure Valve - 1994-1997 Power Stroke FAQ
Old Jan 5, 2012 | 01:09 PM
michaloco's Avatar
michaloco
European Enthusiast
i just unplugged it, works fine for me.
Old Jan 5, 2012 | 01:32 PM
PowerstrokeRyan's Avatar
PowerstrokeRyan
I just unplugged it for a temporary fix on a long haul upnorth. Then took turbo out and rebuilt it while i welded the plugs shut. Not that hard just a time consuming job. Many have done.
Old Jan 6, 2012 | 10:42 AM
rockndb's Avatar
rockndb
WELCOME a board
Thanks for the welcome! I tried the exhaust break mod but I couldnt get it to work. Voltage right to it had no effect, and disconnecting it did not stop it from activating when the truck is cold. Oh well...
Old Jan 6, 2012 | 12:05 PM
DIYMechanic
It sounds to me like the solenoid or the cylinder has failed. You should be able to wire (tie) the linkage open to keep it from closing.
Old Jan 12, 2012 | 06:54 AM
Abelexcavating's Avatar
Abelexcavating
What position is the guide in on the outside of exhaust? Pictures would be plus. Thanks
Old Jan 12, 2012 | 08:16 AM
DIYMechanic
The rod on the pedestal should be in the OUT position to have the EBPV OPEN. In is closed I believe.
The rod should be out toward the passenger side VC to open the valve. I don't have a great picture, but this one gives you an idea what you're looking at.
wyo_rangeman
Nov 11, 2008 09:03 AM
Copedawg
Nov 24, 2007 09:13 AM
Failsafe
Apr 6, 2007 03:29 PM
Twinkie111
24
Jan 22, 2007 12:01 PM
mcdavidson
Nov 7, 2006 04:02 PM
