spout connector?
Old Jan 24, 2007 | 10:56 PM
fe8u's Avatar
fe8u
Question spout connector?
where is the spout connector located on a 95 f150 speed desinty system i've checked by the dissy, did not see anything that look like that
thanks chad
Old Jan 25, 2007 | 06:06 AM
jroehl's Avatar
jroehl
The spout on a '95 is near the driver's-side fender, near the ECU test plug.
Jason
Old Jan 26, 2007 | 12:35 AM
fe8u's Avatar
fe8u
would it be a pink wire all by itself?
thanks
Old Jan 26, 2007 | 06:06 AM
subford's Avatar
subford
Here is a diagram and a photo.
http://i54.photobucket.com/albums/g9...s/TFISPOUT.jpg
http://i54.photobucket.com/albums/g9...tion/SPOUT.jpg
Old Jan 26, 2007 | 07:33 AM
arctic y block's Avatar
arctic y block
Thanks Bill I was wondering the same thing.
Old Jan 27, 2007 | 12:08 AM
fe8u's Avatar
fe8u
thanks a bunch chad
Old Jan 27, 2007 | 10:14 AM
arctic y block
So you unplug the Spout To time the engine in the same way you would pull and plug the vacuum to the dizzy to time the engine with a light? And when was it first used?
Remember no dumb questions, only dumb answers.
Talk about feeling old.
Old Jan 27, 2007 | 10:47 AM
subford's Avatar
subford
Yes, that is right.
It started with the TFI Module Ignition that was computer controlled in the mid 80s. You could not time the older DuraSpark III computer Ignition system
By the way you do not list any trucks that would have a SPOUT jumper but the earlier TFI Ignition system had the TFI Module mount on the distributor and the SPOUT was under the distributor.
Old Jan 27, 2007 | 01:05 PM
arctic y block
Thanks Bill that will go in my CRS folder. I work on all kinds of rigs in my shop in the summer when the tourist season is high. This info will be used there.
beefyjerk
Sep 12, 2004 06:23 PM
RyanJake
Jun 29, 2004 06:18 AM
atlstnspc1
Mar 8, 2004 07:58 PM
hokeyson
May 21, 2001 03:02 PM
