power steering leak!
Old Jan 22, 2007 | 09:30 AM
bdunegan's Avatar
bdunegan
have not posted here in a while due to being iced in and busy scraping driveways, but back to the swing of things. my 71 f-250 has a small power steering leak coming from the seal around the input shaft. truck has been setting, so i am sure it is dried out. is there anything to swell this seal, or is it difficult to replace. dont want to take it off onlyto find it looks like a swiss watch when i get it apart. anyone?
Old Jan 22, 2007 | 11:25 AM
Unimog005's Avatar
Unimog005
um....well.....I can tell you this...I had to have mine "rebuilt" to get it operational....doing so required finding a "donor" pistol as well as my original, and paying an additional $495 to have a new center piston fabricated at a CNC shop, as the two originals were too pitted to reuse. The assembly process for the piston at the shop took almopst two weeks....as they must weld "soft" metal to "hard" metal and can only do about 3/4 " at a time before setting the piece in a bucket of sand to cool.
When I asked around....I was told there were no more parts available...but obviously the PS shop found some somewhere that worked.
Old Jan 23, 2007 | 07:26 AM
390fe's Avatar
390fe
Unimog, I hope your pump is different than mine...$52.99 with exchange at my local O'Reilly auto parts store. And they have it in stock. Cardone Industries pn# 20-6098.
Old Jan 23, 2007 | 07:43 AM
390fe's Avatar
390fe
Sorry guys, I haven't had any coffee yet. After rereading the posts, I see your talking about the steering gearboxes. And yes, those 3/4 ton ram assist steering systems are unique.
Old Jan 23, 2007 | 07:44 AM
bdunegan's Avatar
bdunegan
I may have mislead someone on my post. the leak is not on the pump itself, but on the steering box. the leak is on the end where the steering shaft from the column goes in. pump and hoses are fine. seen new boxes listed fairly cheap, but wanted to prolong mine as much as possible. know the seal is dried out from setting, but dont know how hard it is to change. sorry about the mis-info
Old Jan 23, 2007 | 07:49 AM
390fe's Avatar
390fe
Cardone Industries pn #27-7504. $144.99 with exchange. For a '71 F250 two wheel drive. At O'reilly's.
Old Jan 23, 2007 | 08:20 AM
390fe's Avatar
390fe
In 1987 I had new seals put in mine for $75 parts and labor at my local Ford dealership. Labor rates have gone up since then.
Nope, not mislead, I just didn't read carefully. :-)
I'm a gearhead now, so I'd try to fix it myself before I let someone else do it for me. In 1987, I was 15 and didn't know squat.
Old Jan 24, 2007 | 04:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford part # C2RZ-19C548-A P/S Sealer & Conditioner
It used to work....
eladnermai
May 3, 2013 10:13 AM
zsir
Nov 30, 2005 10:20 PM
nminer1
Aug 25, 2005 09:30 PM
1968 F250camper
19
Jan 10, 2005 09:10 PM
dazman
1978 - 1996 Big Bronco
Jun 8, 2004 11:30 PM
