Power steering box woes
I changes some ball joints last year on my 86 F250 with a 351W. Must have stressed the seal in the power steering box because it has leaked ever sense. Leaks around the splines. The leak use to be a drip here and there. Now it is an occassional gusher. Never swapped seals on a power steering box before. Can it be done for this model and year truck? Can't find any literature in the hayes manual to replace this seal? Can I do this job with just a pitman arm puller and a pick? Or is it more complicated?
Can it be done with the power steering box in the truck? The splined shaft appears to be the one with a leaky seal. Not looking forward to pulling the box out of the truck. Your comment on worm gear/seal/bearing wear makes me think the box has to come out. I'd like to just pull the pitman arm and replace the shaft seal and be done with it if possible.
eladnermai
05-03-2013 10:13 AM
Gatrucknut
01-01-2011 05:43 AM
fzeed
06-21-2009 11:58 PM
Alex from GA
11-02-2005 08:08 PM
